Solved Vista update KB2446708 problem - failing to install
Jahad
3
Hey all,
I'm having problems installing the NET framework 4.0 update. Every time my windows update tries to install the update, it fails to do so and tells me it hass encountered an error. Error code 643. Googled everything, been round forums, but cannot find a solution.
I've tried using microsoftfix it tool for this update, doesn't work.
Tried uninstalling previous net framework version 3.5 and reinstalling, no luck.
Can anyone help?
Many Thanks
    Dell (Inspiron 1720)
    Intel Core 2 Duo T9300@ 2.5GHz
    (I have no idea - not very IT coordinated)
    nVidia GEForce 8600MGT
    Factory Fitted
    Single Display - Laptop
    1 x 320GB
    Touchpad
    QWERTY
1,351
Location
Canada
Hey all,
Can anyone help?
Many Thanks
Not sure what you had tried.
Have you tried this tutorial from Microsoft Support ?
http://support.microsoft.com/kb/KB976982
If no luck with the tutorial above, consider asking this question at :
Net Frame Setup forum
.NET Framework Setup Forum
kesume
1,316
Location
Lake District, England
Hi welcome to the forum.
Sorry to hear you had problems downloading that particular update. This link is specifically targeted to the update in question
The article below, although similar in substance to t-4-2 's, is update specific.
Support Article dated as :- April 12, 2011.
Hope this is of some help to you.
MS11-028: Description of the security update for the .NET Framework 4 on Windows XP, Windows Server 2003, Windows Vista, Windows Server 2008, Windows 7, and Windows Server 2008 R2: April 12, 2011
Thank you.
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
Jahad
3
Hi there, thanks for the speedy replies.
Unfortunatly I;ve tried the solutions from the forums even before posting here and I;ve just tried them again, no suck luck in installing the update and my NOD32 is fuming...saying that "maximum protection may not be ensured". I;ve decided to show you the exact error message I keep getting:
OS Version = 6.0.6002, Platform 2, Service Pack 2
OS Description = Vista - x86 Home Premium Edition Service Pack 2
CommandLine = C:\84eaaed6a894525af9afd9e5c0\\Setup.exe /x86 /x64
TimeZone = GMT Daylight Time
Initial LCID = 2057
Using Simultaneous Download and Install mechanism
Operation: Installing
Package Name = Microsoft .NET Framework 4 Setup
Package Version = 4.0.30319
User Experience Data Collection Policy: AlwaysUploaded
number of applicable items: 11
Exe (C:\84eaaed6a894525af9afd9e5c0\SetupUtility.exe) succeeded.
Exe Log File: dd_SetupUtility.txt
ServiceControl operation succeeded!
Exe (C:\84eaaed6a894525af9afd9e5c0\Windows6.0-KB956250-v6001-x86.msu) failed with 0x1 - Incorrect function. .
MSI (C:\84eaaed6a894525af9afd9e5c0\netfx_Core_x86.msi) Installation failed. Msi Log: Microsoft .NET Framework 4 Setup_20110415_162501978-MSI_netfx_Core_x86.msi.txt
Final Result: Installation failed with error code: (0x80070643), "Fatal error during installation. " (Elapsed time: 0 00:05:26).
Hope this information helps
P.s I've cleared my temp folder and reinstalled the netframework versions up to 3.5 but when I try installing version 4 I still get the aformentioned error in installation. It gets stuck halfway and fails to install.
Many thanks
    Factory Fitted
    1 x 320GB
    Touchpad
    QWERTY
kesume
1,316
Location
Hi Jahad,
This one update does seem to be causing you a problem.
After, like you no doubt, doing research on this, I came across this site which may be of interest.
0X80070643 Error Repair Guide
Hope it helps.
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
Jahad
3
Hey, found a solution to this error, simply just keep trying till it works. I left the installation of NEt 4.0 for a while and it just installed itself sucessfully.
As for the ssolutions you found Kesume, the page was great, but the software I downloaded just told me of the problems I already knew, and to fix them I;d have to fork out £70....in my opinion I've already paid for the OS therefore support for any dodgy update should be free irregardless of whether it's from microsoft or someone else.
Anyhoo, it's safe to say this topic can be closed. Thanks for all the help guys!
    Factory Fitted
    1 x 320GB
    Touchpad
    QWERTY
kesume
1,316
Location
It sure is good that it got fixed through pure determination. Well done you! The NET framework updates can be tricky.
Thank you for keeping us informed.
Great, Happy Computing.
I'll mark solved!
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
longvale
2
#8
Re: KB 2446708 failing to install. Tried to install several times with no success. Went to Control Panel> programs and features> framework 4 client profile> uninstall. The dialogue box gives you a choice of repair or uninstall. Chose repair. It took quite a while and thought it had hung half way thru but it completed ok. Reinstalled KB 2446708 and again it also appeared to hang midway but it completed successfully. Hope this helps
ShawnR
2
#10
My other reply wasn't clear what I was replying to. I tried the reinstall of the framework 4 and it appears the problem is now corrected. I'm unclear why we have to research this problem that Microsoft appears to have created, but in any case, it appears corrected now.
kesume
1,316
Location
#11
Hey, thank's for that tip.
Also thank you for sharing it with us, as others can benefit from your experiences.
Glad you worked it out.
Thank's.
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
longvale
2
#12
Hi zaniac625.. if the extra updates are not causing any problems it may be best to leave them be. Another option if like me you find the problem an irritation is to uninstall them one by one and see what happens if anything. Another option would be to do a system restore to before this pesky KB first came on the scene. (Each update downloaded from Windows creates its own restore point so it shouldn't be difficult to go back to pre KB2446708.) Before trying to install it again try repairing the Net framework 4 client profile as per my previous post. Warning this could turn out to be painful if it doesn't do the trick!! Remember the old adage "If it ain't (currently) broke don't fix it!!"
6
#13
Many thanks Longvale for the prompt answer and sound advice about leaving well alone. I tried a system restore beforehand but when I tried to update the same fault suddenly appeared. Thanks - I will let things rest
