Vista Upgrade
Valzan
1
I installed a copy of Vista Ultimate that had been an XP box a couple of years ago and it has been humming along happy as a clam ever since. Recently I caught a virus and thought that I would just install another instance of Vista on a different drive on the same machine and just migrate my applications over time. This is my photo editing machine so it is really important to my business. In the process of trying to install Vista it wouldn't recognize my SATA drives and long story short I had to reformat the IDE drive that Vista was previously installed on and install it there. Of course I had done backups to my external drives so I didn't lose any data but. For this installation, because I no longer have the XP disk (moved three times) I installed without entering the serial number thinking I would find the old disk which I can't. How can I get this copy activated again?
Thanks,
Valzan
    Home Brew
    Athlon Phenom 8450 Triple Core 2.1 GHz
    XFX nForce 750a SLI v 8.11
    2 GB
    NVIDEA nForce 750a SLI
    Realtek
    NEC LCD 2090UXi
richc46
Staff member
20,105
Location
Fairfield County, CT
Welcome
Im very sorry, the so called serial numbers are probably the key numbers. Without those numbers you cannot use Windows for more than 90 days. The key is the only proof that MS has that you actually bought the OS and did not just install it.
