Vista won't boot up normally but safe mode will work.
Iijima
Yo~!
This is my first time posting here and I must say that I've felt very welcomed and I have been learning a lot through reading through all of the knowledgeable things that you guys have posted. My problem has been going on for a while but has recently gone over the edge and caused me some big problems. I play Second Life and from time to time, it would freeze up my computer but yesterday, the screen of the laptop just went black and I had to hard reboot my computer, only for it to come up with the Vaio screen looking horrible graphically. Then it would commence to the normal boot up and then to a black screen and it stayed there all night. I've tried removing everything with Second Life off of my computer and it still won't boot up completely. I tried leaving it on overnight to see if would bypass the black screen but it wouldn't. How should I go about fixing this? I can try getting my hands on the Vista DVD and or the recovery disks from my girlfriend. I would honestly just like to know what caused the problem and how to fix it because you can easily learn from your mistakes by fixing it. Oh, another interesting tidbit is that my brother used the computer beforehand to do some research then left it on and when he came back, the screen was black and when he rebooted it, the screen was messed up and he did a system restore to bring it back to normal but if I tried that now, it would still only boot up in safe mode and not regularly.
fadedrs
Lost in my own World
Power User
try updating your video card drivers, also since you can get into safe mode you could try to do a system restore to an earlier date when you know it worked..
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
Iijima
Oh, I've tried the whole Safe Mode method with System Restore but the system still won't boot up completely. The screen stays messed up on the initial Vaio boot up, then it just goes back to the black screen, where I end up waiting forever.
fadedrs
Power User
what video card do you have?
or what system / model # do you have? if it is not custom built.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
fadedrs
Power User
give me min will get you links.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
fadedrs
Power User
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
fadedrs
Power User
let us know if it worked or not, and also if you need any more help
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
Iijima
Okay, they wouldn't let me do the first Vaio update because they won't allow the Windows Installer to go through and the video card one didn't work because they said that they didn't detect it on my computer for some reason. So back to square one~
fadedrs
Power User
a clean install is always better than a repair but you could try the repair first and she if that fixes the porblem if not than you could always do a clean install.
word of advice though, buckup everything you want to keep before you do either one.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
Iijima
Hey, Fadedrs.
The repair didn’t work but I actually have an idea. I don’t think that there is anything wrong with the video card or anything but I think that I just have some freaked out computer virus. Do you have any programs that I can download to try and possibly figure out what the virus is and weed it out before doing a clean re-install?
Iijima
I recently ran a VAIO Hardware Diagnostics and these were my results:
= CPU Test Start =
CPU Test 1 OK
CPU Test 2 OK
CPU Test 3 OK
CPU Test 4 OK
CPU Test 5 OK
CPU Test 6 OK
CPU Test 7 OK
CPU Test 8 OK
CPU Test 9 OK
= No error was detected. =
= Memory test start =
Memory access Test OK
= Video Test start =
Video Test #1 Failed
Video Test #2 Failed
Video Test #3 Failed
= Errors were detected. Verify that the hardware accelerator is set to the maximum value. --- (E-VIDEO-008) =
= CF/PC Card Controller Test start =
CF/PC Card Controller Test OK
= HDD Test Start =
Drive 0
Linear Seek Test OK
Errors were detected on this VAIO.
fadedrs
Power User
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
fadedrs
Power User
sounds good hope it works. if it does not a clean install should get rid of everything. just make sure you do a full format and not a quick format.
    CUSTOM BUILT BY ME
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    CABLE 15MBPS
Iijima
Do you guys have any tutorials on clean installs and full formatting? I used to do it all the time on XP but this is my first time doing it on Vista.
