You should upgrade or use an
alternative browser .
Solved Vista won't start and mouse and keyboard (both Wireless) don't work
I have recently purchased Vista Business and it has been running OK for about a week with some assistance from Microsoft support. This morning I woke up and the system won't boot. I put the Vista disc into the PC and I get a page that comes up called "Install Windows" with 3 selections:
Language to Install
Time and currency format
Keyboard or input method
However my mouse and keyboard do not allow me to make the appropriate selectios or click the "next" button to continue.
Can anyone help?
Thanks
Scoop
Gigabyte S-series GA-G31M-S2L
2GB
View Sonic
wireless
Wireless
Broadband
Hello Scoop, and welcome to Vista Forums
If they are USB, then double check in your BIOS settings to make sure that you have a "USB Keyboard/Mouse Support" at dos or boot type option enabled.
You might also test by having the wireless receiver plugged into different USB ports to see if it may be a problem with that USB port.
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
TerraMaster F8 SSD Plus NAS
Logitech MX Master 4
Galaxy S23 Plus phone
Operating System
Thanks Shawn,
The problem rectified itself after 4 days. I think I might have a Hardware problem, but we'll see if it happens again.
Thanks Heaps,
Scoop.
2GB
View Sonic
wireless
Wireless
Broadband
Scoop,
I'm happy to hear that it seems to have sorted itself out for you.
Operating System
Operating System
