OK I have had this problem and usually I end up reformatting but there has to be a solution.
Vista x64 Ultimate is blocking MSN ( Keyports and DNS ), Limewire ( stating blocked due to firewall ) and IE 32bit can't connect to the internet. 64 bit IE can connect.
I am assuming it has something to with Network settings and configuration Between IPv4 and IPv6.
When I try to set the IP for port forwarding, I get nothing, the internet becomes disabled.
I have searched through the forum and as of Yet have not found my answer.
By the way I have disabled the firewall and Bit defender at the moment.
