Vista x64: Can I install ffdshow (x64) or do I need "Vista Codec Components" too?
sofakng
I've just installed Vista x64 and I'm a little confused on how to get ffdshow working (64bit version).
If I just install clsid's latest ffdshow x64 then it doesn't work. Even if I switch media player to 64-bit (eg. unregmp2.exe /SwapTo: 64, or something) then it still doesn't work.
Do I need to install this thing called "Vista x64 Codec Components" (or whatever it's called?). Really I want is ffdshow (64-bit) to work...
Also, does the Haali Media Splitter work? It doesn't seem to work at all in Vista x64.
Thanks for any help!
Well, a Codec is something that you install to use a certain type of video file, such as a codec is needed to play DVD's on your computer. I would try installing it, and see if it works then.
Haali seems to be a virus from what i know about it. Stay away from that...
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Tarantula
    Razer Lachesis
    not fast enough
Hi sofakng, welcome to the board.
Sorry I can't give you an absolute answer but here is an excellent link with great instructions. I don't think it will hurt to give it a try.
Hope this will help.
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
The only x64 codecs you'll ever need or use, are available here: Vista Codec Package Homepage (VCP).
I've been using them for nearly 2 years now, and have yet to encounter a video that would not play.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
