Vista64 problems
kabalp1
3
Hi there!
A have few problems with my fresh Vista Ultimate 64bit OS. :sick:
  • Sometimes boot takes too long, hard restart than it boots up. In many cases explorer.exe hangs/freezes at sturtup, a have to manually end the process then restart it.
  • Some programs started from quicklunch have a 30+ sec.delay.
  • In start menu it takes years to get to an entry (for example MS office group to open...), a search indicator is shown instead of icon and it hangs too.
  • When watching any video file mplayer classic freezez (like the old school w98 freez, sound shakes, screen stops..) for a few secs than it continues. Downloaded VLC player, it wokrs for now... but this isn't the solution anyway. I use VistaCodecPack with 64bit components.
  • In normal use I have 60 processes in background (at the moment there are 14 svchost.exe-s and 8 control.exe-s ?!!?!?). One antivir is running, I am behind HW firewal and windows firewall is on..
These are my problems with this fresh install. I didn't had any trouble at install, in 50minutes I had the OS on th go with drivers installed.
I have tried the sfc /scannow tip > Windows Resource Protection did not find any integrity violations, hmm..:shock:
Had a multiboot befor : XP + Vista + win7beta, I just get rid of it..thought Vista is the right joise for my hardware at the moment.
I don't know what to do with these problems, if someone has any idea, please give me an advice what should I try.
Thx!
    Costum
    AMD X2 3800+ @ 2100MHZ L2-512KB
    Microstar K8N Neo4-FI, MS-7125 (nForce4)
    4GB DDR - 4x1GB DIMMs in DualChannel @ 210MHz
    ASUS - NVIDIA GeForce 9800GT (G92)
    Realtek AC'97 5.1 on board
    HP LCD 24" - w2408h
    1920x1200 @ 32bit
    80GB SATA WD (SystemDrive)
    120GB SATA Maxtor
    640GB SATA WD GreenPower
    Enermax 350W (still enough ;) )
    Mercury KM-82
    CPU - ArcticFreezer64 + 12cm vent. on side panel
    Microsoft Laser Mouse 6000 USB
    Microsoft Comfort Curve 2000 USB
    2048 Kbit /512 Kbit
    It's an older hardware tuned up for media...
kabalp1
3
I cannot even boot to Vista now (surfing from laptop :( ). Just tried a restart than nothing (not even to safe mode). I'll check the errors after a repair :confused:. But I think there will be some HW issue, maybe motherboard too old for 64 bit Vista...
    Costum
    HP LCD 24" - w2408h
    1920x1200 @ 32bit
    120GB SATA Maxtor
    Mercury KM-82
    2048 Kbit /512 Kbit
kabalp1
3
Hi there!
It finally worked out... donno what wuz wrong. I have dismanteled my pc, changed some sata devices order and cables than put it back 2gether. Now it works fine.
Meantime I have installed win7 to try if the problem presists there too, it did.. but now both OSs are running without problems.
Thanks Flavius,
    Costum
    HP LCD 24" - w2408h
    1920x1200 @ 32bit
    120GB SATA Maxtor
    Mercury KM-82
    2048 Kbit /512 Kbit
