Visual studio 2005 in 64-bit vista
yesh95
hi folks,
I have a vista home pre 64 bit os. I tried to install visual studio 2005 standard edition but i am unable to install as visual studio 2005 is 32-bit supported and my os is 64-bit. Please help overcome this problem.
Thank you
richc46
I will look it up for you, what is the complete name of the program?
richc46
There is professional, standard and team suite. Which one do you have?
richc46
If you have Standard Version 8, it should work. Microsoft says that it is compatible.
I will try to help. Tell me exactly what it says when you try to install.
yesh95
Isnt standard version 8 and 2005 the same??
The messabe is:
The version of this file is not compatible with the version of windows you're running.Check your computer's system information to see whether you need an x86(32-bit) or x64(64-bit) version of the program, and then contact the software publisher
richc46
Do you get the message every time you try to install, or when you try to use it?
Yes, you are ok with 8, same as 2005, but I was trying to be sure I knew what you had.
richc46
yesh95
I dont quite understand.... how can i install Visual Studio 2005 Service Pack 1 Update for Windows Vista before even installing visual studio 2005?
richc46
I am still searching, but you should install the service pack after the installation.
One possiblity is that the DVD is bad. It really should install.
derekimo
Moderator
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    250GB Samsung 850 EVO SSD
    1TB WD Blue
    1TB Hitachi
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
    Laptop specs: HP g7-1365dx /
    CPU: AMD A6-3420M APU with Radeon(tm) HD Graphics /
    RAM: Crucial 8Gb (2x4Gb) /
    SSD: Crucial M4-CT128M4SSD2 ATA Device/ FW 000F /
    GFX: AMD Radeon HD 6520G /
    OS: Windows 10 Pro x64
richc46
derekimo
Moderator
    Asrock P67 Extreme4
    auria eq2367
    1TB WD Blue
    1TB Hitachi
yesh95
I did so and i got this message:
Windows cannot find 'G:\setup.exe'. Make sure you typed the name correctly, and then try again.
