Solved VOB files problems
mich
I am having problems with burning DVD.
I burn a DVD from My TV DVD recorder they are VOB files they play back perfectly.
I then transfer from the DVD+RW disc to my Ext HD again they show as VOB files
I then want to watch this Movie on my TV so I burn to the same disc this is where it all goes wrong, I have used Windows Media Centre and Ashampoo.I have done this as VOB files also converted to mpeg2. Asv, DivX the results are :
Mpeg2 and asv good pic but sound out of sync
DivX pic terrible but sound in sync.
Please! What am I doing wrong.
Running Vista home
Hello and welcome
Can you tell us a little more about your system (Like)..
1. Manufacture
2. Model Number
3. Laptop or desktop
4. (OS vista home premium 32)
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    HP Multimedia Keyboard
    Microsoft Wireless Mouse 5000
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
Even though the VOB files are indeed DVD format, you will need to create a folder tree on the disc for it to be recognised, instead of just dragging the files over to the disc and burning them, you will need to create the folder tree within some DVD making software, it shouldn't be a timely job as the files are already DVD format, also with certain DVD software, you can create menus and chapters for your DVD.
Burn a DVD-Video disc
MrNeeds
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
For a DVD to play in a DVD player, it has to have two folders:
AUDIO_TS
VIDEO_TS
I don't know why but the AUDIO_TS folder is always empty whereas the VIDEO_TS folder contains your .VOB, .IFO and .BUP files. If you only have a .VOB file then you are going to need some software to create the other two so that it can be played in a DVD player.
I can't confirm whether this does actually work because I don't burn videos in the way that you're trying to, but apparently Nero Burning Rom will do this for you.
What I do is to convert the .VOB files into .wmv (well I don't actually do this, I rip the DVD straight into a .wmv/.avi file) and burn that using Windows DVD maker. I would recommend that you use Any Video Converter as I have used this in the past and its great.
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
Running Vista home
1. Vob files are not supported by Windows.
Below are the audio/video formats accepted by Windows.
• Video files: .asf, .avi, .dvr-ms, .m1v, .mp2, .mp2v, .mpe, .mpeg, .mpg, .mpv2, .wm, and .wmv
• Audio files: .aif, .aifc, .aiff .asf, .au, .mp2, .mp3, .mpa, .snd, .wav, and .wma
• Picture files: .bmp, .dib, .emf, .gif, .jfif, .jpe, .jpeg, .jpg, .png, .tif, .tiff, and .wmf
Google for a free video converter and convert your vob into WMV. WMV is the most reliable format among the list of formats that are supposedly supported by Windows.
2. You have Home Premium which has Windows DVD Maker included.
If you want to burn DVDs and be able to watch them in any portable DVD players or compuers, use Windows DVD Maker (WDVDM ).
Just open (WDVDM) and add the video file and start burning. The procedures are quite simple.
I have tried WM Centre which I thought did support VOB I have also tried Ashampoo. the files that I have are:
AND
I have tried converting to WAV via 'Any Video Converter' same results I have also tried Windows DVD Maker
AND
WAV is an audio codec. You need to convert to WMV (Windows Media Video).
Try converting to WMV and using Windows DVD Maker.
If that fails, try this converter:
VOB to WMV Converter - Rip and Convert VOB to WMV Free Download
And use Windows DVD Maker
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
I have success at last, I installed ‘Quick Media Converter’ and converted to :
PAL DVD Format HQ .mpeg (16:9)EUR. Then burned to DVD via Ashampoo (free version) now playing on dvd recorder and TV, sound is in sync and pic OK .
I assume that ‘Any video converter’ has a bug I will un install and re install.
Thanks for your replies, suggestions and help. Much appreciated
If Quick Media Converter works, then just keep it!
Glad to hear that you've solved your problem and thank you for sharing the solution.
Tom
Edit: Thread marked as solved
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
