Want to use USB network adapter instead of internal wlan card
talamoth
Hi. My new Dell XPS 1530 laptop has an internal wlan card which does not seem to pick up the network signal strong enough. I am constantly disconnecting and the download speed will begin around 11mbps and, very shortly, drop to about 1. My (very) old Dell desktop has a Lynksys external network adapter that picks up the signal strong enough with no problem. Never disconnected. How ironic that I am forced to use my old Dell desktop with this brand new notebook sitting here.
Anyhow, I ordered a WUSB600N Ultra RangePlus Dual-Band Wireless-N USB Network Adapter and am wondering how to disable the internal wlan card in order to try the external adapter. My OS is Vista 64.
Any help would be appreciated.
THANKS!
Roxanne :cool:
pooch
Old Dog
THANKS!
Hi Roxanne
Roxanne :cool:
Hi Roxanne,
Welcome to the forum.
Some laptops have a switch near to the keyboard so that you can switch it on or off
You could take the old network card out of the laptop,
You could also go to Device Manager Right click on your Network adapter and select disable.
I hope this helps
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Drive #1 - SAMSUNG HD252HJ (250 GB)
    Drive #2 - Hitachi HDT721010SLA360 (1000 GB)
    Drive #3 - SAMSUNG HD250HJ (250 GB)
    Drive #4 - SAMSUNG HD103UJ (1000 GB) External eSATA
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
    I have also used Fedora, Suse, Ubuntu Linux
    And all other Windows from 95 to date except ME
