wanting to switch back to xp
badognobisc
debating to switch back to xp 64 bit system. first lets hear your best pitch as to why i should keep vista compared to xp. second I did read a website that said microsoft is allowing owners of ultimate to go back to xp at no additional charge for a key code. has anyone done this or know of anyone that has switched back.
thx for the words
badog
SCSIraidGURU
You can't easily go back. You would need a clean install for XP x64. You need to backup data.
    16GB DDR667
    SAS RAID
Bare Foot Kid
R.I.P. August 13th 2014
If that's what you want to do... go ahead!
Later ;) Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
badognobisc
already have a new 500 gig hard drive to either install xp or throw in as a third hard drive for vista.
wanted to know opinions of group comparing vista to xp.
waiting to decide what to do after hearing from the group.
my feeling is vista offers better security but xp is faster and more dependable.
please stick to the topic not trying to be rude but trying to weed out to get the answers I am searching for.
SCSIraidGURU
As BFK stated, you computer and your choice. Vista is the future. XP is the past.
    16GB DDR667
    SAS RAID
SCSIraidGURU
I did a clean install of Vista x64 Ultimate. I was on XP x64 SP2. Vista works great.
    16GB DDR667
    SAS RAID
dmex
ɠɛɐǨ
XP is over 10 years old and things like PCIE, SLI, Memory, SATA, and CPU extensions plus hundreds of other things are just not supported very good under XP and will never be updated or fixed...
I support Vista because it has hundreds of advantages over using XP when they are compared, In my opionion you do what you like but Vista is worth learning and using :geek:
TheShadow
Retired PC Builder
As a working tech I have customers using everything from Windows 98, to Vista Ultimate.
It won't be long till XP will go the route of 98 and ME. Out of date, No support and NO new drivers. The people writing new software and new hardware drivers for the current systems are NOT writing anything with XP in mind.
Why would they, since Vista is obviously here to stay?
For many PC's and Laptops on the dealers shelves today, there are NO XP drivers. Period. Not now, Not ever.
Probably more so with the Laptops than with the desktop PC's.
Now on the other side of the coin, there is a possible user base of millions of users still dependent on XP.
While, Vista is only being used by a very small percentage of the total PC users worldwide.
I have two SATA2 Drives on my MSI/AMD based system. Drive one has XP/Pro/SP3 on it and that's my main system. While drive two has Vista Ultimate/SP1 on it and it's my development and training system. My PC boots into XP by default. To get into Vista, I Press F11 at boot to get a boot menu, from which I can choose the Vista drive.
I've tweaked and tuned Vista to look and act as much like my XP/SP3 as possible. I've done the same for every new system I've set up since Vista was released.
If done properly, Vista can almost be an XP clone, albeit a lot larger on the HD.
I see no reason to remove it and try to get one of these new systems to accept XP.
That could be one heck of a job and basically UN-Productive.
Like XP, I'm sure that Vista can be stripped down to eliminate the fluff and clutter.
I've not had the time or patience yet, to start disabling Services, like I did when I first got XP. Some geeks are already working on it and I understand that they are making great headway.
Now, for the person with just a modicum of technical expertise, I'd suggest installing a second HD in the system and install XP on it and set up a dual boot system like mine. Then just see if you can find the drivers to make it work. Sorry, this won't work on a laptop, but only a tower with enough space for the second drive.
Then if worse comes to worse and the proper XP drivers cannot be found, format the XP drive and use it as Storage. Nothing ventured, nothing gained.:geek:
Anyone wanting to go back....has my deepest sympathy. I felt the same way about XP when it first came out. I really didn't want to give up 98/SE with all the goodies I had added. XP was like an 800 pound Gorilla in the room.;)
Y'all have a great day now, Y'hear?
The Shadow :cool:
    AMD Athlon Dual Core 5200+
    MSI K9N Platinum
    4 gigs DDR2-800
    WinFast
    Integrated
    19" Envision LCD
    2 Maxtor 160 gig SATA2
    1 Seagate 200 gig SATA2
    Antec Earthwatts 650
    Pac Man
    13 fans
    MS-Digital
    Generic
    Cable-5 meg
    Homemade, under constant mod.
johngalt
Antidisestablishmentarianist
One thing to remember - at the end of this month M$ stops shipping XP preloaded. At the end of April 2009 you stop getting any free support from M$ for XP.
As previously reported, Microsoft is requiring PC makers to stop preloading Windows XP on new machines after June 30, 2008. Microsoft support for XP doesn’t end on that date; free Microsoft-provided support for XP continues through April 2009. Microsoft “Extended” support — for which users must pay (other than for security-specific hot fixes and various self-help tools, which are free) — lasts through 2014.
About those Windows XP ‘upgrades’ from Vista … | All about Microsoft | ZDNet.com
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
