Web page and image can't appears!!?
ardebeli
Hello,
I have vista home basic-servicpack2- IE9+norton security2011 that these days are very sluggish:(, many Web page does not appear and if after seconds go open the content is not displayed completely , particularly images remains empty, i have to click (Show picture)to view, so it goes with opening of my emails too,further loading videos such as youtube takes a very long time which remains in buffering :mad:, if I use skyp the connection will be interupted all the time if I turn off the webcam without the video it goes well, windows indicates that problem cannot be solved automatically by using the network and sharing Center, I've checked he is well connected to the internet and internet signals are strong, i have this internet connection for more then year and all those cases which slowing down now has been functioning perfectly so it's fast enough, I have reinstalled setting of norton security and Internet option to standard and i have ruined system recovery but it didn't solve the problem:o!!!do you have any idea what solution maybe?
your help is appreciated
  • Name
    koraal19
    Packard bell-I Media
Yard Dog
  • Name
    Bill
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    Acer E181H ([email protected]) 128MB GeForce 6150SE nForce 430 (
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
    Country Flag
    usa
    State/Region Flag
    us florida
richc46
Welcome
Your problem can very well be the result of malware as suggested above; but memory may also be a cause. Run the tests as given above. If they are negative, I am rather sure that you will find a problem with memory
Guide to using Memtest86+ - Geeks to Go Forums
  • Name
    Richard
    Country Flag
    usa
    State/Region Flag
    us connecticut
wither 3
You could try Express Cleanup in IE to help speed it up.
You could run the Windows Disk Cleanup utility from Accessories and reboot to remove temporary files and empty the recycle bin. Sometimes temporary files can really slow a system down.
Does the home basic have the Aero? If so, you could turn it off.
Just some easy things to try along with the other suggestions.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
