WebCam Help
Maldini
Hey fellas,
I gotta annoying little problem here....I am trying to open the following link, its a security camera but I can't view the cameras for some reason. I opened it in firefox, safari n opera n the page just says
"Depending on the internet bandwidth, it might take a few minutes to download the software" but nothing really downloads I left it open for hours with no luck. When I try to open it in IE....it opens up a new tab for some reason with the following address:
http://207.81.129.51/Install_WebCam_Bmp.exe
n then after a couple of minutes IE just freezes n restarts.
I am running vista n I been told that might be the problem but I don't think that's the case. I also think I might need to download some add-ons but I am not sure wat kind of a add-on I need. Can anyone help me with this?? Any help would be appreciated
The link is....
http://207.81.129.51:7070/
Thanks
Hi Maldini,
Have you contacted the manufacturer for help with the DVR setup?
Steven
Hey fellas,
The link is....
Thanks
