Weird GPU Dual Display Bug?
Ten2O
For some reason, my GPU won't show up as a display option in display settings while I have onboard enabled and are using it as a secondary display, but it is still used fine when I had onboard disabled and are using it as a main display in the bios. This is not a problem in XP. GPU: GTX 750 ti
    Vista x64 Business and XP IE Dual Boot
You already have a thread on this issue and we're trying to help there.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
But I solved that problem, I set it to GPU only in BIOS and it showed up and displayed Aero fine. So it can't be a problem with the drivers or a glitch with the card, it's a glitch with Vista. Anyway, I guess I'll just go there and update the main post.
