A few days ago, my laptop froze the first time ever and I had to restart it (using the power button). When I then started it, everything would go fine until after the Microsoft loading bar thing (when the screen is black and the mouse is in the middle). I can move the mouse at that point, and if I press Caps Lock, the light goes on, but it doesn't move on to the welcome screen. I left it on the whole night to see if anything happens at all, but it doesn't move. Alt+ctrl+del doesn't work. Safe mode loads the welcome & logon screen, but after that the screen is black with safe mode written on top and corner and the mouse is there and you can move it, but nothing else shows up.
What's funny (well maybe not) is that I installed ubuntu a while back (the -install as a program on windows- version) to try it out and see if it's that different and I kept forgetting to uninstall it and when I select Ubuntu as my operating system when I turn on my computer, it works :D
Yea, Ubuntu works perfectly. So i can access all my files and basically do almost everything on here, but I'd still miss Windows because of some programs ..
I tried repairing the computer (i inserted the vista disk), but it found nothing. I did a memory test (basic), but it's all nothing. :/
I did a "check disk for errors" test and it shows nothing and when the computer turns on after that, the windows loading bar takes forever and when it reaches the blank screen with mouse phase, it stays there for a while and then restarts.
So...
Any suggestions?
I should probably mention this too: I dropped the laptop from about 1 meter the night before it stopped working. But after it fell, I worked on it for about 2 hours more and it worked fine. Then I hibernated it (as usual) and when I turned it on the next morning, the problem appeared. But the fact that ubuntu works suggests that it's not a physical computer problem, or is it?
Thanks for all help.
So...
Any suggestions?
