Solved What are the correct C++ redistributables?
RoloDman
My friend has Vista basic 32 bit and I would like to remove and reinstall all the Microsoft C++ redistributables on her system.
1. is this safe to do?
2. can somebody please tell me which ones to install and if there is a particular order I should follow?
FYI, I am hoping it will solve a "side by side" error she is getting. :geek:
Hello!
1: Not particularly. Trying to uninstall will likely make the problem worse. These redestributables do not need to be uninstalled. Just install them again, on top of the old installation, and the problem will be fixed if this is the root cause.
2: All of them. In the order they were released.
FYI: Side by Side? Relatively common problem. In theory at least, my speciality. Follow both of the below posts:
Hello!
This is one of the very worst error messages to receive, and could be almost impossible to fix. Primarily, try what Lorien has suggested above, in particular System Restore. If absolutely necessary:
· Download and install the following VC++ Redistributables in the following order: 2005; 2005 SP1; 2008; 2008 SP1, 2010
Web addresses:
1. Download details: Microsoft Visual C++ 2005 Redistributable Package (x86)
2. Download details: Microsoft Visual C++ 2005 SP1 Redistributable Package (x86)
3. Download details: Microsoft Visual C++ 2008 Redistributable Package (x86)
4. Download details: Microsoft Visual C++ 2008 SP1 Redistributable Package (x86)
Download details: Microsoft Visual C++ 2010 Redistributable Package (x86)
· Install .Net Framework in the following order: 1.0 SP3; 1.1 SP1; 2.0 SP1; 3.0 SP1; 3.5 SP1, 4.0, Windows Installer 4.5
Web addresses:
1. Download details: Microsoft .NET Framework 1.0 Service Pack 3
2. Download details: Microsoft .NET Framework 1.1 Service Pack 1
3. Download details: Microsoft .NET Framework 2.0 Service Pack 1 (x86)
4. Download details: Microsoft .NET Framework 3.5 Service Pack 1
5. Download details: Microsoft .NET Framework 4 (Standalone Installer)
6. Download details: Windows Installer 4.5 Redistributable
Now, restart your computer. Hope desperately that this has fixed your problem, otherwise things get seriously technical!
Richard
In theory at least, this problem can be corrected. There are two things that you must do.
STEP ONE:
Right, please run steps 1, 2A, 3 (about 15 minutes), 4, 5, and then Step 1 from the top yellow box, but only follow this last one if Integrity Violations were found. Please upload the new sfcdetails.txt from your Desktop. System Files - SFC Command
STEP TWO:
This step will be more helpful, but is more complex.
1: Get three different programs which all generate this error message lined up ready to run.
2: Open an elevated Command Prompt. Elevated Command Prompt
3: Type sxstrace trace -logfile:sxstrace.etl into the Command Prompt window, and press enter ONCE! Set it continue to log!
4: Start the first program. Let it generate the error message, and OK out of the error message. Once the program has closed, start the next program. Once this one has closed, start the last one. Make sure that all three generate an error. I need you to make absolutely sure that you do not run programs that work while logging!
5: Go back to the Command Prompt and press enter again to end the logging.
6: Type sxstrace parse -logfile:sxstrace.etl -outfile:%userprofile%\Desktop\sxstrace.txt and press enter.
Upload the file sxstrace.txt from your Desktop.
Please make sure to include both sfcdetails.txt, and sxstrace.txt in your next post.
Thanks!
Richard
Good luck!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Thanks for all the great tips, Richard. I tried installing all the C++ and .NET files and it did not solve the issue. My friend does not have the patience to go through all the other steps and decided it would be better if she just purchased Windows 7.
thank you for your help
