VFN
What's the difference between uninstalling a game through the control panel and deleting the game folder and saves folder. In fact, what's the difference between the two when is comes to any program. Is it only the registry?
I ask because I had trouble uninstalling a game through control panel due to an uninstall error. I suspect the trouble was due to a folder I deleted that I shouldn't have. I deleted the game folder and saves folder and the control panel then told me the game didn't exist and would I like to remove the entry from the programs list.
So I'm trying to understand what it means to install a program that appears in your control panel and what it means to uninstall it.
If I haven't made myself clear just tell me to get it together.
Thanks.
Thanks.
- Operating System
- Vista Home Premium x64
- Dell Inspiron 546
- Sempron LE-1300
- 2GB DDR SDRAM 800MHZ-2X1GB DIM M
- Graphics Card(s)
- Integrated ATI Radeon HD3200
- VIA High Definition Audio
- Samsung 32" HDTV
- 1366 x 768
- 320GB NCQ Serial ATA (7200 RPM) w/ 16MB DataBurst Cache
