Solved What is a LocalLow folder?
idahjo
Bush did it....
In my AppData folder I have three folders: 1)Local 2) LocalLow 3) Roaming.
Is the LocalLow folder serving any purpose?
Brink
Staff member
mvp
Hello Idahjo,
I found this that helps answer what they are for.
http://support.microsoft.com/kb/955555
Windows uses the Local and LocalLow folders for application data that does not roam with the user. Usually this data is either machine specific or too large to roam. The AppData\Local folder in Windows Vista is the same as the Documents and Settings\username\Local Settings\Application Data folder in Windows XP.
Windows uses the Roaming folder for application specific data, such as custom dictionaries, which are machine independent and should roam with the user profile. The AppData\Roaming folder in Windows Vista is the same as the Documents and Settings\username\Application Data folder in Windows XP.
idahjo
Bush did it....
That was a short fix.
%^$*%^ thing just keeps coming back!
I was checking LocalLow out originally and thought I would be wise and just scoot it to the desktop so I could put it back if it needed it. It allowed me to scoot it to the desktop, and recreated another LocalLow file in the AppData where it came from.
I have downloaded the program from the tutorial that creates the "TAKE OWNERSHIP" tab. With it I can delete the LocalLow folder from the desktop by stripping it to the trash from the inside out, then dumping the trash. Have even tried changed the folder names and it keeps returning to 'haunt' me!
From Brinks tutorial I see it must be one of those TRUSTEDINSTALLER buggers... now that I have it stuck on my desktop how do I get rid of it? :cry:
Brink
Staff member
mvp
Not sure why you moved it since it is a system folder, but you might try to Move it back to it's original locaction to see if that may help.
idahjo
Bush did it....
That would be two of us! I [admittedly] have a limited computer knowledge and work [obviously to hard at it] trying to increase my knowledge. I read some about getting rid of unnecessary clutter to speed the start up. I was nosing around and spotted this unfamiliar folder that I did not recall seeing on some screen-shots of others. Sooo... what I said above!
It won't go back as it was done awhile back and the AppData file created a new one to replace it. 'Should have been named the Frankenstein file!
..REALLY SCREWED-UP, HUH? :o
Brink
Staff member
mvp
#8
LOL, well your not learning if you not breaking something. ;)
If it hasn't been to long ago, then you may be able to do a System Restore using a restore point dated before you moved it to see if that can fix this.
idahjo
Bush did it....
:o Trouble is that applies when you are young enough to remember to not do it again... when you get older, you ask yourself "did I do that before or didn't I ? ...Where did I put that whatchacallit??"
{Didn't think so, but] I had a system restore point that went back far enough, so it got dumped! :party: THANKS Brink!
Brink
Staff member
mvp
#10
LOL, I hear that. I think I had broke everything at least a few times or so. I think. ;)
I'm happy to hear that you got it sorted out. :)
#11
OK, sorry for digging up this old thread, but I had this question too. What exactly does this folder do compared to the plain vanilla "Local" folder?
And what is "Roaming"? What does that mean? Is that software specific?
#13
Hey , ok so one question from me: Is it safe to delete the LocalLow folder?
I'm asking cause my C system drive has only 50GB space and it just somehow went to only 2GB free space. I deleted temp files, restore point and all that ,but it didnt really free up much space....then i saw that the LocalLow folder is taking up 31.8 GB!!!!! :O which is more then a half of my system drive space.
So like I asked, is it safe to delete this folder? or not?
#14
Hello Rasmasyean,
Between the two reference links below, basically this:
Windows Integrity Mechanism Design
Designing Applications to Run at a Low Integrity Level
AppData\Local = files too big to roam or specific to that computer
AppData\LocalLow = an area for low integrity apps to write to, e.g. Internet Explorer add-ons.
Ok so my question is ,can i delete the LocalLow folder? or not? cause for me its taking up 31.8GB of a total 50GB system disk space that i have.
Please just yes or no answere. I really wouldnt want to have to re-install the whole system again if this folder CAN be deleted safely :)
Thanks in advance!!
#15
In the future, it is better to start a new thread rather than revive an old thread that is well over a year old. :)
Do not delete this folder. However, open it up and do a properties check on the sub folders and see which one(s) are taking up a lot of space. Based on this, deal with the associated program (like purging cache). Note that there is also a "Temp" sub folder and you can also delete files in there.
You also might want to do a disk cleanup on C: drive, just to be sure all unnecessary temp files are cleared out.
#17
Hey thanks for the reply Cytherian although the one that was taking up 31.8 GB was Sun Java folder and i deleted it and as i can see there are no problems so far :)
And yeah i did run ccleaner and cleared cache,temp files and even doine the disk cleanup but that didnt work. So I deleted it :)
#18
The Sun Java folder can end up with older versions of the runtime, but I'd never heard of it accumulating over 30Gb of files. That's huge! For some reason, Sun (or Oracle now) hasn't been very good about cleaning it up, perhaps wanting to keep older versions around for compatibility with older Java programs, but I couldn't imagine that much file space being taken up. It's possible you had a Java related virus that was using your computer to store files. I would definitely download Malewarebytes again and run it to be sure there's nothing left over.
Anyway, in deleting the Java folder outright you may have compromised your Java installation, if necessarily program files were deleted from it. Check your installed programs list (Programs and Features in the Control Panel) and see if you have multiple entries there. You might not be able to delete those with all of the files gone. In any case, you may not need Java depending upon what you do in your browsers. Some browsers install it by default and allow it to update automatically, even if you're not accessing web pages that use Java. If it is needed, you'll probably have to install a fresh latest version of Java.
