What is <user>.V2 ?
dustinfrank
Dork
Power User
98
Location
Spring Hill, TN
I noticed this morning that there is new directory in my 'Users' folder which is my user account name + .V2.... <user>.V2. I did not create this but it does have a creation date of Nov 13th 2008. Could this be at all dangerous? Does anyone know what it came from? Nothing shows up scanning with AVG, Ad-aware or spyware terminator, so i'm not -that- concerned with it... Still, i don't like that i didn't create it and its there. It seems to be a copy of the primary user folder that its named after. AND its only on my user account, not my wife's.
Thanks for your opinions,
Dustin
    Dell Optiplex 745
Barman58
Staff member
1,786
Location
Newport, South Wales, UK
Hello Dustin,
Do you share files on this PC from an XP computer with the same username?
If this is the case it may be caused by certain differences in the implementation of roaming profiles between XP and Vista. It would be more usual on a Domain based setup but if deferences exist in the structure of a local and roaming profile, it may be created in a workgroup. In this case it may be safely deleted.
Have a look at discussion here ...
User.v2? - dslreports.com
If this is an isolated machine however I would advise you to scan for malware with Spybot S&D and malwarebytes.
Spybot-S&D!
Malwarebytes.org
  • Show second system?
    No
    Operating System
    Windows 10 Pro 1709 Fall Creators Update (16299.192)
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    2 x 1920x1080 @50Hz
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    WDC WD30EZRX-00D8PB0 3TB,
    Toshiba HDWD130 3TB
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB +1TB
    Wireless Logitec - MX Master + M570 Trackball
    Wireless Logitec MK710 + K400+
    37.8 MB Down 9.5 MB Up
dustinfrank
Dork
Power User
98
Location
Spring Hill, TN
No the only other machine in the house is a Vista Home Premium laptop. Do you think Spybot and/or Malwarebytes would find something that ad-aware and avg did not?
The only other thing authorized to copy anything on the machine is Acronis, but of course that's just imaging/backup to a separate external drive.
    Dell Optiplex 745
Barman58
Staff member
1,786
Location
Hi Dustin,
It could just be some type of glitch that has caused the creation of the extra User branch, Hopefully that's the case.
I would however, recommend that you do a full scan with both the packages as they are specifically targeted against Trojans and the like, and there removal, whereas AVG and ad-aware are more tailored to stopping virus attacks getting onto the machine.
Both packages are free for private use and are useful additional tools to keep available, they will quite often find things that others do not, unfortunately, due to the multi-pronged nature of today's malware attacks we have to take the same route to stop them.
Hopefully, as I said above this is not malware, but it's worth while checking.
    No
    Operating System
    Asus M5A78L-M USB3
    2 x 1920x1080 @50Hz
    Internal
    Toshiba HDWD130 3TB
    External (USB3)
    NAS 4TB +1TB
