Whats messed up ?
On start up lately, the computer freezes, goes black, and tower unit beeps.
Unplug it and start up in safe mode, then back to normal start up OK.
First time, all Norton definanitions gone and Vista defender shut off. restored them,
all OK.
Tried to back up files and got i/o device error (Ox8007045D).
Then, tried to chkdsk...and nothing happens. ????
Have run Norton Internet Security full scan, and Lavasoft Ad-aware. Also Registery
Mechanic....
Vista HP, Gateway 5656
smarteyeball
Eye know, eye know
What sort of beep is it?
A single short beep is normal.
If it's a single long/longer beep that could indicate a hardware problem.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
roy69
47,65,65,6B
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
smarteyeball
Eye know, eye know
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
CrucialHoax
Action is Knowledge
all OK.
Mechanic....
To me sounds like the hard drive is dying. If you can't run check disk nor can you invoke disk activity by backing it up, those are big hints right there.
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
JimJoe
if checkdisk runs, then its not the hard drive.
Check your CPU cooling. Is the fan working, is the CPU running hot ?
I would also check for any loose, or not seated fully, cables.
    Acer Aspire X1700
    ASUS
    3 gigs
    EVGA 1 gig GeForce 210
    Vizio 21" tv
    1920x1080 resolution
    fans that came with it
    basic USB
    basic USB
CrucialHoax
Action is Knowledge
Correct, if check disk runs hd is good. It happens only upon boot up correct?
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
Yes, only happened that one time a few days ago.
I'm beginning to suspect Norton. At least 2 times a yr it seems to goober up
the system. When this happened, it also had error 3035,2 .
Even chkdsk'ed drive D and compressed it. OK
Thanks all for the feedback.
CrucialHoax
Action is Knowledge
Everything is running a-okay?
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
Knock on wood....yes, so far that was the only incident.
As for the fan working...yes the cabinet fan is working, I
don't know of one inside the unit, have not opened it up. I have
in the past opened up the Compaq and used compressed air to
blow out any fluff.
