Solved When Laptop's Idle For Extended Time
VFN
If you don't use your laptop much, if it's going to see no use for more than a day, maybe several days, should you shut it down or is it okay to just close the lid. Turns out my father won't be using his Asus Notebook much as he bought it for the sole purpose of navigating a site that once, but no longer (I had to break the news to him. :shock:), required IE. (I recommended that he use Boot Camp or a virtual program on his Macbook Pro before the site became Mac friendly but he didn't listen.)
Thanks.
    Vista Home Premium x64
    Dell Inspiron 546
    Sempron LE-1300
    2GB DDR SDRAM 800MHZ-2X1GB DIM M
    Integrated ATI Radeon HD3200
    VIA High Definition Audio
    Samsung 32" HDTV
    1366 x 768
    320GB NCQ Serial ATA (7200 RPM) w/ 16MB DataBurst Cache
richc46
This has been an argument that has been going on for years. There is no harm to the computer if it is not used but
If you shut if down, you are sure you will not get a virus while not in use. You do not have to surf to get a virus.
You will save on elec bills and there will be no extra, although very, very small wear on the hard drive. The hard drive wear is that is prevented is cancelled by the extra wear by booting.
Personally, I leave mine on unless: I am going out or there is a thunder storm.
VFN
So it's the same debate as desktops. Thanks.
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
richc46
Yes it works the same way. I have a desktop.
townsbg
~~тσωηsвg~~
Sleep uses battery power/electricity to keep programs (and the OS) running in memory. Personally I put my system to sleep at night and when at work as well as utilize the timeout option. If I where him and barely turning it on I would shut it down when not needed.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
