Solved Where can I install Active X
Jillian
I mistakenly uninstalled the Actve X control and cannot find where to reinstall it.
I have Windows Vista 64 Bit Home Premium . I also have IE9 64 Bit and 32Bit installed. I use the IE 32 bit because it is faster.
So , can someone tell me where to go to install Actve X. And which one ,
64 Bit or 32 Bit.
Thanks in advance for your help.
    2.67gb IntelCore2Quad6700
    Asus
    NVIDIAGeForce8600GT
    500GB
    500GB
    10GB
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
That link took me to download IE. Which I already have. I accidentially deleted the Adobe Active X control in the add/remove programs and now Adobe will not install using IE. When I go to see a video , it tells me that I need to update Adobe Flash Player and when I try to install it , it will not install.
My problem is getting Adobe Flash Player to install. Not IE
    Asus
    NVIDIAGeForce8600GT
    500GB
    500GB
    10GB
If I do a directory of *.ocx, which is the extension for active x controls, I get 138. So when you say you accidentally uninstalled "the activex" I had no way to get a clue other than you mentioned IE.
Installation problems | Flash Player | Windows
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Thanks I solved my problem
    Asus
    NVIDIAGeForce8600GT
    500GB
    500GB
    10GB
Please share so that others will know what you did.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
