Solved Which ones to install first?
Mariel1679
I did a clean install using the tutorial as a guide on a 64 bit machine. It was seamless and worked perfectly. Now I have 70 "important" updates, but I am hesitant because I don't know which ones I should install first. They are not dated as far as I can see unless I look at each one individually. I have downloaded to my computer but not installed any yet. Using SP1 from one year ago. Any suggestions would be appreciated.
    Dell XPS M1530
    Intel Core 2 Duo T8100 @ 2.10GHz
    4.00 GB Ram
    NVIDIA GeForce 8400M GS
Re: Clean Install with a Full Version of Vista
Hello Mariel, and welcome to Vista Forums.
I would recommend to only install the ones that it has selected by default, and to not select any others to install at the same time. Afterwards only install a few at a time to avoid them possible conflicting with each other during installation.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Ok thank you for prompt response. The thing is, all 70 are selected. So I thought maybe I should select the earlier dates first. But, for instance, the SP2, does it contain cumulative updates from before it was issued? or should I go back and install all the earlier updates before doing SP2. Thanks for your advice.
    Dell XPS M1530
    4.00 GB Ram
I would install SP2 first, then the other updates a few at a time afterwards. :)
I just reinstalled my pre-SP1 Vista today. I ran into about 100 updates today and there is no end in sight because I am not even at SP1 level yet. I installed all hundred without a problem. I prefer big batches because of the permanent rebooting one needs to do.
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
    6 external disks 60 to 640GBs
I found that I have to install the SP1 important updates before I can install SP2. So I am doing that now, but slowly and carefully. Thanks for your advice.
    Dell XPS M1530
    4.00 GB Ram
