White Square on upper corner of Desktop.
gordonfreeman
Ok so there's a really old thread about this already. But it didn't solve my problem. When I boot vista, a little white square appears in the upper left corner. It's not my wallpaper. On the old thread they have resolved the problem as being an ATI GPU Driver problem, and the update fixed it. But here's my problem, I don't have an ATI GPU.
When I right click the little white sqaure I can open up its properties, and in the properties it has a name of some website. Shortly after I even read it a "close program" window comes up. I click on close and the sqaure dissapears until the next time I boot.
Leaving the white square on just messes with whatever programs Im running. For example: If im watching a movie in full-screen, it will randomly just exit out of full screen. It doesnt do that once the white sqaure is off.
Well thanx for hearing out my problem, any help would be great.
stoneys-nutz
Gamerholic
Hello gordonfreeman,
Try these two free apps, run Malwarebytes then CCleaner. (backup your registry when prompted).
Malwarebytes.org
CCleaner - Download
Hope this helps, good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
gordonfreeman
Malwarebytes.org
CCleaner - Download
I ran both programs, however the white square is still there when I boot. I really did like ccleaner, it's fast and cleared some other issues. Thank you for that. I've also cleaned my registry and that hasn't helped either.
Here's a screenshot of my desktop with the properties of that white square open, and the error message I get. You can see the white square at the very top left.
Win2Kuser
I have the same thing on my Windows 7 box. I guessed it was a bit odd when I right clicked on it and noticed the link. The link incidentally tries to use ieframe.dll to open a web address to no doubt download some spyware of some description.
Anyways, I noticed in the Task Manager that I had a SUSB.EXE loaded which didn't ring a bell, so I ended the task, and the box disappeared. I also noticed that in my Startup folder was an entry for Wireless which pointed to c:\windows\syswow64\susb.exe. I removed that and job done :)
Ed Canuck
Power User
Hi Gordon,
If Win2Kuser's suggestion didn't work, could you do the following:
Download and run http://www.vistax64.com/tutorials/176785-vistaforums-sysinfo-tool.html (Click on Select All, then click on the Windows logo). After it runs, export to a file and upload the file with your reply (see Vista Forums - FAQ: Reading and Posting Messages).
Open Windows Explorer, click on View > Details, and navigate to C:\Users\YourUserID. Click on Desktop and take screenshots of each screen of listings, then do the same for C:\Users\Public\Desktop. Upload the screenshot files in a zipped file.
Ed
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE
    1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech MX100 Laser
    Logitech LX710
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
