Solved why are the exact same posts on eggheadscafe?
Hello Anon, and welcome to Vista Forums.
The newsgroups here are mirrored from the Microsoft Public newsgroups. Since the newsgroups are public, other websites can mirror an access them to. When you post something in a newsgroup, it will show up at every website that decides to mirror them as well.
Only posts in the Vista Forums stay only here at Vista Forums, and can only be accessed by members of Vista Forums.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
So posting in the newsgroup section on this forum is NOT mirrored on the newgroups?
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
I believe that if you post in the newsgroups here, that post is sent on to the Microsoft forums and would then appear everywhere.
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    2-WD5000AAKS-500 GB
    WD 5000AAV-500 GB external
    Microsoft Comfort Curve
    MX Revolution
    Wacom Intuos 2 Graphics Tablet
    Experience Index=5.5
Thanks Gary do I believe you're right. I tried it out earlier, checked the MS newsgroup and it didn't appear, then just checked again and it did. The delay through me.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
I'd guess that any post made here is updated to the MS servers on some devious schedule arrived at by the Admins. :sarc:
Gary
    Creative SB X-Fi
    HP w2207 + HPvs15
    2-WD5000AAKS-500 GB
    MX Revolution
Yes, the newsgroups will be updated to the MS Public newsgroups and any other website that also mirrors them. This is why you will see people with a Guest title under their username sometimes instead of the usual ones for our members.
The Vista Forums can only be seen and posted to from here only.
You're welcome Anon.
