Why does my computer keep shutting off?
I never had this problem until I recently cleaned up my computer. It now runs fine, but my problem is that the computer shuts off, without warning, every 10 minutes.
How can I stop this?
Patonb
How'd you clean it?
Does it just shut off? or a bluescreen?
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Yard Dog
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Patonb
I'd check your cpu and gpu temps. They can cause shut offs like that.
The random shut offs have stopped it seems. But I now have a new problem. Whenever I turn on the computer, I either get the blue screen errors or an error that says the CPU fan has failed.
Also, I'm having trouble staying connected to the internet. The other computers in my house aren't having this problem, so it's just mine.
Patonb
Open your case and see if the fan is moving or not.
If its not, its the cause of all your problems.
Yard Dog
You are going to be buying a new fan .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
