Why softwares aren't working?
Softix
I had this problem since I upgraded to Vista. All softwares I used before in Windows XP worked without any problem, but most of them now support Vista and they are giving me tons of problems everyday.
What is this happening?
rajinisback
Vista Pro
Software makers have got to rewrite their code to make it work with Vista. Keep checking the maker of the software websites for Vista updates.
Raj
Brink
Staff member
mvp
Hi Softix,
You might try using XP SP2 Compatibility Mode on the program to see if will run or install better with it.
How to Use Compatibilty Mode in Vista
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Brink
Staff member
mvp
Your welcome Raj,
LOL, it's an easy feature to overlook if you do not use it. ;)
    Lumia 1520 phone
