Will System Restore recover deleted device driver?
Quite simply, I went into Device Manager (in my administrator account) and uninstalled my Novatel Ovation U727 USB modem and its device drivers because I was having problems with the modem deactivating itself from the USB port whenever I was online.
I then rebooted and plugged the modem back in, thinking Vista would detect the modem and reinstall the device drivers for it. However, it seems that uninstalling the device drivers actually completely purges them from the system. I tried using the Slingshot driver CD that came with the modem and my Windows DVD to find the missing device drivers.
I then went into Device Manager and searched online for drivers. I was able to retrieve device drivers for two of the four data interfaces that the modem apparently needs drivers for. I was able to get drivers installed for the modem and status port (com 4) components, but apparently there are two others that need device drivers.
I've already looked on Slingshot's website, but they don't have any drivers available.
Windows came with these drivers by default, so there must be a way to retrieve them without completely reinstalling Windows. Would using System Restore get back the uninstalled drivers?
I'm attaching a screencap of my Device Manager to show what I'm talking about.
    Toshiba Satellite X205-S7483
    Intel Centrino Core2 Duo 1.7 GHz
    Toshiba ISRAA 1.0
    2 GB
    nVidia GeForce 8700M GT 256 MB
    RealTek HD Audio
    x2 120 GB
    Logitech Trackman Marble Wheel USB
    Logitech USB
    Millenicom 3G Mobile Broadband @ 1 mbps
    Avast Antivirus Home Edition 4.8.1335, Firefox 3.0.11
stormy13
Best I can say is it should, as long as you use a restore point that is before you deleted things. It has worked for me in the past in restoring drivers after a bad update install.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
Thank you. It did recover the drivers. The random deactivations do remain a problem however, even with the option for Windows to deactivate things disabled.
    Toshiba ISRAA 1.0
    2 GB
    RealTek HD Audio
    x2 120 GB
    Logitech USB
