Windex Worries - An Object Lesson
NormCameron
This tale of woe sounds a cautionary note for the more fastideous amongst us:cool:
A couple weeks ago I received a Dell Inspiron 6400 from a friend of mine. I was told that he used Windex directly on the screen, which dripped into the bottom of the LCD (between the screen and the housing). It now has a small, permanent “white fire” pattern on the bottom-center of the LCD screen. It appears not to be a physical effect, as I cannot see it when the laptop is off, but I can see it even when the backlight is turned off.
What should I do to fix my display?
—Jason Wesley
The Doctor has some bad news for you: Your situation is terminal. In this case, your laptop will require a screen transplant, as the Windex has irreversibly damaged the underlying layer of your panel. Even if you use Windex to clean a laptop’s screen—and the Doctor doesn’t recommend you do this—you need to resist the urge to spray it willy-nilly over the entire surface. Instead, spray a little bit on a cloth and use that to buff out your screen’s blemishes.
Ultimately, your screen will fare far better if you spritz a microfiber cloth with an alcohol-based LCD cleaner and give your screen a rub. You can make your own using a 50-50 mix of 70 percent isopropyl alcohol and distilled water. Or, if you’re feeling lazy, you can pick up a premixed screen cleaner from your computer store
Ask the Doctor: Windex Worries | Maximum PC
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Microsoft
    Targus
    1500kbs
    Self built.
Never really had a problem here computer cleanliness is not my strong point.
However I could sometimes use some help when it comes to my keyboard Harvest ;)
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Drive #1 - SAMSUNG HD252HJ (250 GB)
    Drive #2 - Hitachi HDT721010SLA360 (1000 GB)
    Drive #3 - SAMSUNG HD250HJ (250 GB)
    Drive #4 - SAMSUNG HD103UJ (1000 GB) External eSATA
    Enermax Chakra
    Standard
    Easy Line Laser Mouse
    I have also used Fedora, Suse, Ubuntu Linux
    And all other Windows from 95 to date except ME
You can share your harvest as there are food shortages everywhere.:)
    Acer Aspire 5920gmi notebook
    NVIDIA GeForce 8600M GS
    Realtek
    crawl
Hey you're right, there must be a way to make €€€€€ here!! :party::party:
    Self build
    NVidia 9600gt
    AD1988b
    Enermax Chakra
    Standard
ROFL yeah "A Friend of Mine" *cough* :rolleyes:
Windex is basically bleach for Glass not pixel crystals...He should have expected a dead screen from using it :shock:
I use them little hand wipes from MacDonalds and Hungry jacks to clean my LCD, They work great ;)
...........and would you like fries with those Sir?? A deep-fried Sepoy to thrash, perhaps??? - Have a nice day!:D
    nVidia GeForce Go 7300, 128MB
    1280x800x60Hertz [max.]
Supersized if possible thanks...I dunno what Sepoy is but no thanks..Oh and keep the change ;)
Sahib MacDmexstein is indeed one of most generous proclivity.....rest assured the 5c will be spent wisely, after much due pondering and consideration.:D
Off subject, but.......
Sipahi...from Persian and Hindi..means Soldier. Introduced into English language by the Lords and Masters of the British East India Company as Sepoy, a general term for Soldiers employed by them, and later broadly applied by members of the Armed Forces to anyone of lower rank [normally Private], who was used to perform menial tasks. The Sepoys in the late 1850s instigated a 'failed' revolt or mutiny against their British Officers and Other Ranks....all which leads to this small exchange...even further off subject!!
India....a British Outpost....1857.
Colonel Commandant;- "Sar'Major!!!"
Sergeant-Major:- "Sir!!?"
Col.Comdt;- "Sar'Major....the Sepoys are Revolting!!!!"
S.M;- "The men may well be, Sir!! I agree!! However, I find the women particularly ravishing.....Sir!!!;)
