z3r010
Staff member
    Windows 10
    me
    Asus RAMPAGE V EXTREME
    Creative
    6 @ 2560x1440
    3x 1TB Samsung Evo 840's
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
hclarkjr
Vista Pro
here is my score
    intel core 2 quad Q9450
    gigabyte EP45-DQ6
    8gb Gskill PC6400
    Visiontek Radeon 4870x2 2GB
    X-FI fatality FPS 7.1
    Viewsonic VG2230wm
    1680X1050
    VelociRaptor WD1500HLFS 150GB 10000 RPM,
    WD CAVIAR black 750GB
    Antec TruePower New TP-750 watt
    Cooler Master HAF932
    XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
    comcast 16mb\second
Brink
Staff member
mvp
Here is mine. The integrated graphics hurts my score, but it does what I need it to do.
NEW WEI SCORE UPDATE AT: http://www.vistax64.com/general-discussion/96219-window-experience-index-scores-9.html#post730885
Don't Laugh, :D
Model: Slightly modified eMachines T5048A
Motherboard: Intel D102GGC2
RAM: Two 1 GB PC5300 667mhz sticks
CPU: 3.0 Ghz Intel P4 630 w/HT
VIDEO: Integrated ATI Radeon x200 w/256 MB dedicated RAM
HDD: WDC (WD1600BB) 160 GB, 7200 RPM, 2MB buffer, DMA5, ATA
CD/DVDW: TSST Corp (TS-H652D) ATA 2MB buffer (DVD+R 18x)
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
VS80
Whoops
Try again - This should have a picture this time
Apologies
Mike :o
cyclo
Q6600, Intel D975XBX2, 4 x Kingston DDR 2 PC6400 ValueRam, EVGA GTS 8800 640 MB, 2 x 500 MB Seagate Barracuda (Sorry for the big image, haven't intalled the image editing software yet):
Asky
Here to Help
Here's Mine with the Rig in Sig :
    Intel
    Nvidia 9650M GT
    Asus N80VN-X1 Laptop
    1280 X 800
    1 X 250GB 5200 RPM
    11 MBPS
larryk
Vista Pro
Core 2 Duo E6600 on Intel D975XBX2 Mobo
4GB Patriot Extreme Performance (4 X 1GB)
EVGA GeForce 8800GTS 320MB
WD Raptor X 150GB 10,000 RPM 16MB Cache Serial ATA150 (System)
WD 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s (Data)
bob_c_b
Banned
Might take the quad core leap later this year/early next, but not bad for now...
    Intel Core 2 Duo [email protected]
    eVGA 750i FTW
    2x2GB G.Skill DDR2-800
    2x eVGA 9600GT
    500GB Seagate 7200.10
FightingScallion
Enthusiast
Does anyone else find the score for these processors a little low? Seems odd that 2 GB of RAM is somehow less limiting than a 3GHz dual-core.
Also, are most of you using RAID to get higher HD scores?
Brink
Staff member
mvp
Hi Choogster,
Yes, for now 5.9 is the highest you can get until Microsoft updates the Window Experience Index Score to reflect changing systems over time.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
Brink
Staff member
mvp
It would make more sense, and make things easier to gauge. :)
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
larryk
Vista Pro
I know there are some good posts regarding Windows Experience Score if you want to know more about it.
Here's my summary of understanding: When Vista was released, 5.0 was the highest score achievable based on the best hardware available at the time. I would guess they are using standard benchmarking tools and just readjusting the top end score as hardware improves - hence all the 5.9s.
So your processor is being rated against whatever processor happened to be the best when they bumped the score to 5.9 - note the Q-based machines are hitting the top. As for RAM, it appears to have less to do with quantity and more to do with throughput (operations per second), which encompasses far more than the sticks you have installed. My primary hard drive (WD Raptor) most likely IS the current benchmark and explains the 5.9.
z3r010
Staff member
Ahh that explains a lot, TBH when Vista came out I didn't pay much attention to the scores as my system was crap, now I'm at phase 2 of my new rig benchmarks and scores are at the top of my list.
I think a pair of raptors will be put on order next pay day ;)
    Windows 10
    me
    Creative
    6 @ 2560x1440
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    WinTV NovaTD
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Asky
Here to Help
^Either that or if you wanna save some money get the Seagate 250GB Single Platter Drives,very very fast ,give the more EXPENSIVE Raptors a run for their money :D
    Intel
    Nvidia 9650M GT
    1280 X 800
    1 X 250GB 5200 RPM
    11 MBPS
z3r010
Staff member
I'm just trying to silence my system, so it looks like the raptors could be out then :(
    Windows 10
    me
    Creative
    6 @ 2560x1440
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    WinTV NovaTD
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
