Solved Window opens at default size, not maximized
101
Location
Highlands
I use Vista Home Premium. I have an open source app that I want to be maximized when launched. How can I do this?
I've tried maximizing in 2 ways:
- Using the small square at the top right.
- Dragging the corners of the window to fill the screen.
In both cases, if I close and then re-open, the window has its default size.
Any advice?
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
101
Location
Highlands
Thanks for the response.
You might see if applying METHOD TWO in the tutorial below will allow the window to open as it was when it was last closed.
http://www.vistax64.com/tutorials/70819-windows-explorer-folder-view-settings.html
Maybe my brain is not working properly, as usual. But your thread seems to apply to the folders in Windows Explorer.
My problem is with a third-party application. I carefully read the tutorial (all of which I implemented a couple of months ago to fix a different issue), but I could not see anything that applied to external applications.
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
It will usually apply to applications windows as well. However, it is possible for the 3rd party application to override this with it's on default settings instead. It will not hurt anything to try though. :)
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
101
Location
Highlands
OK. Now I understand :)
However, as I mentioned in my previous post, I've already done the registry tweaks for "Bags", "BagMRU", etc.
You're probably right. Thanks anyway :)
Bongo
35
Location
IOWA
After you get the window the size you want Try holding the Ctrl button & click the X to close the window at the same time it has worked for me.
    Sager NP9170 Laptop
    Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz
    CLEVO P170EM
    12 GB
    (1)Intel(R) HD Graphics 4000 (2)NVIDIA GeForce GTX 675M
    (1)Realtek High Definition Audio (2)Intel(R) Display Audio
    1920 x 1280
    (1)M4 256 GB SSD (2)500 GB 7200 RPM
    Backlit
    High Speed Cable
delphin
Eager to learn
Vista Pro
636
Location
Chennai
right click on the application shortcut and go to properties,
There u can find run, change the value to minimized.
Let me know the result :)
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
    100 mbps(office lan)
delphin
Eager to learn
Vista Pro
636
Location
Chennai
#10
That works fine. Thanks.
BTW1: You probably meant "maximized" :)
BTW2: Sorry for the delay in replying. Your post was inserted 0.00238ms before my own post, so I didn't notice your post until now :(
am so happy that i helped u :)
why don't u give some rep power to me :D
    Wipro
    Intel dq35j0
    8 Gb
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
delphin
Eager to learn
Vista Pro
636
Location
Chennai
#12
    Wipro
    Intel dq35j0
    8 Gb
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
