Windows Malicious Software Removal Tool problem
Status
Not open for further replies.
Kathandbrian
After running this tool - both automatically after updating each month, and having downloaded it and run it manually, I am getting Scan Error codes showing up. The last one showing Codes 0x00000005 and 0x0000054. Can anyone enlighten me please?
EDIT:
After "talking" with MS Tech Support, they could not help, or, have forgotten me! Have been researching and found that there was probably a problem with the download of this Tool from the MS site. I downloaded another copy from SoftPedia, ran it, and it worked perfectly. I suppose it is a case of try, and try again:)
Any way, the problem appears to be sorted.
Status
