Windows Vista Home Premium Key Home Basic Discs
Dane1976
I have recently purchased a new Acer Aspire 5535 laptop. It has Windows Vista Home Premium (WVHP) installed.
The computer came with a number of programs that I am not interested in having on my system. In addition, I was not provided a restore disc. I do own a copy of Windows Vista Home Basic (WVHB).
I would like to keep WVHP as I appear to be eligible for an upgrade to Windows 7 . . . but I would like to reinstall to get rid of all these worthless programs. Can I use a WVHB disc with my new WVHP product key?
Could I install WVHB with the WVHB product key, then use the WVHP key supplied by Acer to upgrade?
Thanks for your time in answering my question. I hope it isn't unclear.
Thanks,
Jeremy
Ardneh
I believe that if you install with the Basic disc the process will offer you a choice
of versions. Choose Home Premium and complete the install. Activate with your
Acer's Vista Product Key.
Ardneh
    Compaq/SR5130NX
    AMD AthlonTM 64x2 3800+
    NVIDIA GeForce 6150 SE
MrNeeds
PC Geek
Ardneh is correct, all versions of vista are on all copys of vista discs, just enter the product key when it prompts you and it will work, but since its OEM it may not let you install cleanly, so you may only have the upgrade option, you can however get away with choosing home premium without entering the product key and install, then enter your product key after its finished.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
