Wired to wireless connection
usher227
Wired to wireless internet using dongles
Somewhere our phones do not have any data plan . That place has a desktop with internet connection . No wifi card builtin and since*It is an ALL in one computer we cannot install pci* wifi card. We can only have wifi adapter or dongles on a usb port.
How safe is to create a hotspot using a dongle . If i use vpn over wifi to connect to the company's network , is there any chance of vulnerability ?*
Also , keep in mind the wired internet is LAN based and the company is reluctant a bit that using dongle will expose the network to sniffers.
Can they hack through the adhoc network created by the dongle into my our LAN* ?*
What kind of adhoc network is created?
Can it be used to hack the pc only or the Lan can be hacked too ? I do not understand the layers involved.
Please provide suggestions.
Thanks.
    windows 10
wither 3
Hi usher227-
I won't pretend to know the answer to your questions.
However, the tips provided here might be helpful-
You might also consider using a router rather than a dongle. I think most of the tips in that link would also apply. You would probably want to use WPA2 and later. As I understand it, there's a new standard for WPA that's about to launch.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
