wireless adapter driver trouble
sndjgr
I just formatted my Packard Bell, which was manufactured solely for Windows Vista Home Premium.
Due to a viral infection, I was unable to make back ups of all the drivers, etc. Now I find that my usb wireless adapter cannot be installed because its respective driver is missing. Or so it appears.. because I downloaded the driver from the Sweex website (adapter model is LW053 Wireless 54G Adapter USB) and Windows can't seem to find it. What do you suggest?
I'd really appreciate your help,
s.
ilikefree
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
americancritic
Hello and welcome to the forum. Because you said viral infection there is a couple of things you need to do right away.
1. Run a full AV scan.
2. Download for free Malwarebytes and run a full scan.
3. I would go to a elevated command prompt and type in sfc /scannow now notice there is a space bewteen the sfc and the forward slash if you have not already done so, this can repair a lot of problems on your system.
4. Sometimes if you put your usb in another slot it runs just fine which would give a little time to figure out what is wrong with the other usb port. I hope this helps.
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
ilikefree
Sorry, I should have said my link is to a driver download site.
    LENOVO 64734VM
    15 inch
    External Speakers
