Wireless connection on desktop PC always disconnects
1
I have Vista home premium on my desktop PC and connect to a D-Link DSL-G604T modem router using a Linksys wireless-g PCI adapter. Some of the time, the PC will connect to the network but if it does, it usually drops out after 5 minutes and then I can't connect again. I get many different error messages each time:
Your modem or router is not available
Cannot communicate with DNS server (10.1.1.1)
There might be a problem with one or more network adapters on this computer
Windows has confirmed that this computer is currently experiencing a network connectivity problem
Connection Interupted
There has been an IP address conflict
My laptop can connect to to the modem fine and doesn't drop out when connected and there connection strength is very good from my desktop when it is connected.
Thanks in advance,
Kieren
Chase
americano
1,571
Location
Merced & Monterey, CA
Hello kieren1992,
Welcome to Vista Forums.
I would suggest you re-install the driver for your wireless adapter.
    HP Pavilion Elite
    Some Amount of Motherness
    6.O GB RAM
    Some Amount of Soundness
    1440x900 & 1440x900
    WD Caviar Blue 500GB
    Some Amount of Voltageness
    Hp Pavilion Elite Case
    Some Amount of Coolingness
    HP: M/N:M-SBQ133
    HP: Model Number: KB0911
    Comcast: 20 MB/S
