wklnhst.dat - Should I remove this? - Scanners not reporting malware
23
I was told that I should scan the file wklnhst.dat (properties say its a DAT file, 11KB) in order to get rid of it. It was in APPDATA/ROAMING - not in a folder- just on it's own, the last item there. This after having my machine repaired of all kinds of malware. But this particular item was never mentioned by the original person cleaning the machine. Not sure if they saw it.
I scanned with with a-squared, Superanti-Spyware and Malwarebytes (all are updated and I have the real time version of a-squared which is always running. None of them report it as malware/nothing is being detected when I scan it (or scan the whole C drive).
Do I really need to remove this? I know dates can be falsified but it says it was created and then accessed on the same date around when I bought it and started using it (the computer). Then it was "updated" this year in June (not by me).
If I should remove it but the scanners aren't picking anything up can I just delete it or is that too dangerous? Hard to find specific 'what to do' info online.
Thanks~
    Toshiba Satellite A135-S4527
    Intel Dual Core Genuine Intel (R) CPU
    2GB + 2GB Flash Drive (with Readyboost)
    [Mobile Intel (R) 945GM Express Chipset Family, Integrated]
    The one that came attached to the laptop - no external monitor right now
    1200 x 800
    256k+
23
hmmm...ok - well maybe someone will see this over the weekend and have advice.:huh:
    1200 x 800
    256k+
MWRed
I'd rather be fishin
Vista Pro
1,130
Location
Evansville, Wisconsin,U.S.
I've been looking for info on that file, and for the life of me, I can't find anything that says that it's bad, even though it's marked as something to get rid of in some cases.
Yeah, hopefully someone will know. I haven't ever personally seen this file. It seems to show up in a LOT of log files when people do scans. There's just nothing saying that it's bad or harmful.
For now i'd just leave it as it is, as it really doesn't seem to be a problem at this point.
I have a file (BOOTSECT.BAK) that showed up out of nowhere at some point and i've read conflicting things about what to do with it. It's supposedly a backup file from a previous OS(even though this is a full version, clean install of Vista). I can't get a straight answer on my file either so I haven't touched it. Better safe that sorry I guess.
    AMD Phenom2 XII 560
    Biostar A780L3L
    4GB DDR3-1333
    xfx 9800 GT
    Creative X-FI Xtreme Gamer
    AOC 22" Widescreen
    320GB
    2 front, 2 back,one side
    Logitech Wireless LX310
    Logitech Wireless
    18/2 cable
23
Thanks for responding. It is an odd one. I do see it listed in log files for people getting online help with malware - but always along with a thousand other files. And nothing ever specific regarding it. :eek:
    1200 x 800
    256k+
MWRed
Vista Pro
1,130
Location
Yeah. I don't know if it's a good or a bad thing that it shows up so much on peoples scans. :eek:
Same with the file I was talking about. Can't seem to find a straight, 100% positive answer for it.
    AMD Phenom2 XII 560
    Biostar A780L3L
    4GB DDR3-1333
    xfx 9800 GT
    AOC 22" Widescreen
    320GB
    Logitech Wireless
    18/2 cable
23
Some computer radio show guys said they suspect it is a leftover virus file from the last major malware cleanup. So, likely harmless (but no promises on that). Nothing is detected when it is scanned by itself by any programs, so far. Still, they recommend to delete it only via an anti-malware program vs. deleting it directly into the recycling bin.
    1200 x 800
    256k+
