Wolfenstein cheats help!
Corp236
hello,
I am currently attempting to find a file on my computer for a game. The game is Wolfenstein, the latest one that just came out in 2009. In order for cheats to be activated, I need to access the wolf.cfg file. However, I cannot locate this file. I am thinking that this file might be hidden, but i dont know how to find hidden files. Any help would be much appreciated! Thanks!
hawkin90
Try this.
Click on the Control Panel menu option.
Click on the Appearance and Personalization link.
Click on Show Hidden Files or Folders.
Under the Hidden files and folders section select the radio button labeled Show hidden files and folders.
Remove the checkmark from the checkbox labeled Hide extensions for known file types.
Remove the checkmark from the checkbox labeled Hide protected operating system files.
Press the Apply button and then the OK button.
Now you should see it!
    DELL Studio XPS 435T
    Intel Core i7 950 @ 3.07GHz
    6GB DDR3
    NVIDIA GeForce GTX 260 1792MB
    Soundblaster™ XFi™ Titanium PCI
    23 Inch Full HD
    1920x1080
    1GB Internal
    2GB MyBook External
    1GB MyBook External
    500GB MyBook External
    Studio XPS 435T
    Logitech G5
    2MB
hawkin90
Glad you worked it out :)
    6GB DDR3
    23 Inch Full HD
    1920x1080
    1GB Internal
    2GB MyBook External
    1GB MyBook External
    Studio XPS 435T
    Logitech G5
    2MB
