Solved Word 2007 - Pre-Installed ( can't find product key)
Hello,
I got a new computer a while back. And in it, it has Microsoft Office Word 2007 ( it was pre installed). I had 25 free trial uses. Now it's locked up and won't do anything. So I guess I used them all.
I found this...How can I renew Word 2007? I really need it. I can't find the product key either!
Locate the Product Key for a Trial product
Depending on how the Trial product was obtained (CD/DVD, downloaded, subscription, or preinstalled by the computer manufacturer, system builder, or reseller), the Product Key may be located in one of the following locations:
Desktop Trial icon when a preinstalled trial is available.
Sticker on CD case or other packaging.
Microsoft Product Identifier Card.
Confirmation e-mail message received from an online download or renewal notice.
    eMachines ET 1161-05
    AMD Athlon 64 X2 6000+ 3.0 GHz AM2 Dual Core
    3gb
    Galaxy GeForce GT 430 - 1gb DDR3 - 128bit Memory Interface
    Realtek HD Audio
    Samsung 23" LED, 1920 x 1080 resolution
    1920x1080
    160gb Seagate
    Cool Master Extreme Power Plus - 500watts
    APEVIA X-Trooper Case w/ Side Window-Blue
    4, 120mm fans. 1, 200mm fan. Sunbeamtech Rheobus-Extreme
    Logitech k800 Wireless Illuminated Keyboard
    150mbps
    Linksys WUSB100
    Insignia 2:1 Sound system.
Thanks for your reply. So, it looks like I would need to purchase a product key to use Word 2007 more?
About that Open Office, How good is it?
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
    Linksys WUSB100
Everyone who uses it likes it. Some of course perfer word. Its just a matter of opinion. Fully compatible with Word. Give it a try. Set up a system restore point first. If you dont like it you can get rid of it with no problems or remnanats.
Yes the software that you had was a come on. They want you to try and like and then buy.
System restore point. Could I not just go into add/remove programs and uninstall it?
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
    Linksys WUSB100
Yes and that is the official way.
However, remnants always remain, some in registry.
If I install and in a week or so Im not happy, I use System Restore, the choice is yours
If you dont want to use SR, I would use Revno, its better than install and uninstall from Control Panel
http://www.revouninstaller.com/
It is downloading now...Big file! How do I create a system restore point?
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
    Linksys WUSB100
I installed it. Seems alright. Thanks for your help.
    3gb
    Realtek HD Audio
    1920x1080
    160gb Seagate
    150mbps
    Linksys WUSB100
Your very welcome, if you like it; its like a free gift for the New Year. Happy New Year.
Hope that you use and enjoy it.
