Word document disappeared: Word 2007
suzanneoc
Hello all,
On the 12th October I was editing a Word 2007 document on my Vista Home laptop. Throughout editing I pressed Ctrl S to save the doc over the previous version. I copied data in from several other files.
I went back yesterday to edit the document again and it has disappeared. The only version of the doc is a previous version dated 21st Sept.
I searched on all files modified after 11th Oct just in case I had saved it under another name. Not in there. The files I copied data from did come up in the search results though, soi knwo the search function is working.
I checked the default Autosave location - not in there.
I checked the recycle bin - the doc is not in there and neither are any ~ files or autosaved files. I haven't emptied my recycle bin for months.
I cannot find a word doc modified afetr the 11th October.
Can it really just have disappeared? It is my MBA dissertation paper and I worked on this edit for an awful lot of hours.
Many thanks.
richc46
  • Name
    Richard
    Country Flag
    usa
    State/Region Flag
    us connecticut
