X Application has stopped working
pcinfoman
I run Windows Vista 32 Ultimate and it was running just fine for the last 4 or so months. I installed it around Christmas of 2007. Now, all of a sudden it gives me the error message (shown below) in various programs (Firefox, IE, Dungeons and Dragons Online, Everquest 2, MS Word, MS Excel, etc). It does not happen when I first launch the program, it waits until I am in it good and have something to lose (open unsaved documents).
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is available.
I have not installed any new software or added any new hardware. The buzz around the net is that it is caused by an MS Update around 04/09/2008. However, I am not seeing any solutions.
This is really irritating. Does anybody have any ideas on how to solve this?
I ran the SP1 update and it did not solve the problem.
Brink
Staff member
mvp
Hi pcinfoman,
You might try running a sfc /scannow command to see if it can find and fix any bad system files that may be causing this. You can see how to in this tutorial if needed.
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
If that did not help, then you can do a System Restore using a restore point dated before this problem started. You can see how to in this tutorial if needed.
Hope this helps you,
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
