Solved x64 File Unlocker
Hi guys,
New around here iv been looking for a file unlocker for my x64 bit system i used to use unlocker 1.8 on my old 32bit system but it seems it isn't x64 compatible can anyone help it would be much appreciated
Thanks
Micky
Yeah I have the same problem...
    mm-vision.dk (XForce)
    Intel Core i7 965 3.20GHz
    Gigabyte EX58-UD4P
    12Gb Kingston 1333MHz DDR3 CL9 DIMM (6 x 2Gb)
    GForce GTX 295
    Viewsonic VX2260wm
    1,920 x 1,080
    1 x WD VelociRaptor WD1500HLFS 150 GB 10000rpm
    2 x Seagate Barracuda 7200.11 1.5 TB 7200rpm
    Corsair TX750W
    SilverStone KL01B-W
    Stock
    Logitech G5
    Roccat VALO
    12Mbit / 1Mbit
Thanks SIW2 I'll give it a try.
I just read on the Unlocker site that the program does not work on 64 bit OS yet. But he is working on it :D
    Gigabyte EX58-UD4P
    GForce GTX 295
    Viewsonic VX2260wm
    1,920 x 1,080
    Corsair TX750W
    SilverStone KL01B-W
    Stock
    Logitech G5
    Roccat VALO
    12Mbit / 1Mbit
SIW2
You're welcome Dane and Micky22 - hope it does the job for you.:)
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
