Solved Zip and unzip
americancritic
Hello
Jonathan_King here is the zip that won't work, this is the message I keep getting
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
Hello
Do I also install the blue window.
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
I had same problem so I downloaded WinRar. Easier to use ...IMHO
Still need more training.:o
    HP Pavilon Elite
    ASUS eK Berkeley
    That's where I keep my beer
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
Yes I did use the link and downloaded it to the download's but I have not yet set it up as I am reading the tutorial first before I double click it or should I run it as administrator...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Have you thought about using 7Zip
It compresses better and works with all zip files.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
OK so I would not have a problem with 7zip as far as opening all mini dump files for BSOD's.
I would use it if I knew it was good for that...Please respond thank you
americancritic
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
I have never had a dump file to open but if it is a zip file it will work. Award winning software, here is the link.
7-Zip
    LENOVO 64734VM
    15 inch
Try to extract the Files to a temp location like your Desktop then Open them manually in Windbg
File > Open a Crash dump
If this works then I would associate .DMP Files with WinDbg
H2S04 said:
Register WinDBG as the default handler for dump files
Another entirely optional step that makes life easier. By registering WinDBG (the main debugger you'll want to use) as the default handler for common dump file types, you'll be able to double-click on a dump and have it open in WinDBG without having to go through the "File | Open..." menu operation every time. This registration needs to be performed from an elevated CMD prompt (run CMD as administrator):
C:\>cd debuggers
C:\debuggers>windbg.exe -IA
You will nedd to replace "debuggers" with the Root of WinDbg
For Example - cd C:\Program Files\Debugging Tools for Windows (x64)
Hope This Helps,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
It's not a problem with the ZIP archive; it is, as Josh said immediately above me, a problem with Windbg's file associations. Follow his good advice!
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
Hello to all.
I have a small problem trying to install the windgb, this is what it says. Ok I uploaded a screenshot. I did download from the link you provided, just about 5 miniutes ago I tried to go ahead and install and this is what came up. Thank you for your help.
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Make sure you have this set up....
    HP Pavilon Elite
    ASUS eK Berkeley
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
I downloaded the link you gave to me, but I did not open it, and went a head and tryied to install it a few minutes ago. When I doubled clicked it to go a head and install it that is what I got it did not give me anything like what you are showing me in your screenshot, it just gave me that box.
Do you want me to go a head and click ok on that box and then see what is does or is there another way you want me to try.
Thank you THW for all your help, I know you have other things to do besides this so it is very nice of you to take some time with me so I don't make any mistakes on this.
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Tom
Download details: Microsoft .NET Framework 4 (Web Installer) install this Tom then run the installer again.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
Hello and thanks I was just surffing the net looking for the framework to download, It said that I only have some of it downloaded which must be the the one from reg download updates.
Thanks I will download and then try the orther again.
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Hello I am not sure about this do I just click ok and go to the next page...Or is this where I need to change the path...
Thanks
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
No, just keep clicking next, if you change the file paths then it's just more confusing.
    16Mb Sky bb
Hello and OK the framework 4 is installed, now I am trying to install the windbg and I get to this point and need to know what I should do, here is a screenshot.
Thanks
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
This is where my expertise stops, never used any of these tools so I'll let mr howling wolves take over
    16Mb Sky bb
Gentlemen I haven't got much further. We need to find and read the instructions.
I think they are posted either here or in 7 Forums.
I am waiting for Rich to come back from vacation but the BSOD Squad guys are buried.
Would love to learn and maybe help out.
    HP Pavilon Elite
    ASUS eK Berkeley
    MS WIRELESS
    MS WIRELESS
    AT&T Uverse DSL
