Drive Name Change
How to Rename a Drive in Vista
This will show you how to rename a drive to whatever you want it to be displayed as in Vista.
If your default drive name is missing or was changed and you did not do it with the methods below, then look for a hidden autorun.inf when you open the drive letter in Computer and right click on the autorun.inf file and click on Delete. Next, approve the deletion.
EXAMPLE: Before and After Hard Disk Drive Rename
NOTE:
This is in the Computer (Start menu) window. (METHOD ONE)
EXAMPLE: Before and After DVD Drive Rename
NOTE:
You will notice that for Devices with Removable Storage there is no Rename option when you right click on the device. (METHOD TWO)
METHOD ONE
For Hard Disk Drives
1. Open the Start menu.​
2. Click on the Computer button. (See screenshot below)​
3. In the Computer window, right click on the drive and click Rename. (See screenshot below)​
4. Type in a name you want to be displayed for the drive and press Enter. (See screenshot below)​
5. Click on Continue in the Access Denied prompt. (See screenshot below)​
6. Click on Continue in the UAC prompt.​
7. When done, close the Computer window.​
METHOD TWO
For Devices with Removable Storage
For example, a DVD drive. This will also work for all the other drives with drive letters too.
CREDIT TO: Member: AvatarOfTheShip
1. Open the Start Menu.​
3. Click on Continue button in the UAC prompt.​
4. In regedit, go to: (See screenshot below step 5)​
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\explorer
5. In the left pane, right click on explorer.exe and click on New and Key.​
6. Type DriveIcons and press Enter. (See screenshot below)​
7. In the left pane, right click on DriveIcons and click on New and Key.​
8. Type the drive letter (EX: E) you want to change the drive name for and press Enter. (See screenshot below)​
9. In the left pane, right click on the drive letter (EX: E) and click on New and Key.​
10. Type DefaultLabel and press Enter. (See screenshot below)​
11. In the right pane, right click on (Default) and click on Modify.​
12. To Change the Drive Name
A) Type in a name (Ex: My DVD) and click OK. (See screenshot below step 13)​
B) Go to step 14.​
13. To Restore the Default Drive Name
A) Leave this empty and click OK. (See screenshot below)​
B) Go to step 15.​
14. The registry should look similar to this now. (See screenshot below)​
15. Repeat steps 9 to 14 if you want to add another drive letter icon to change.​
16. Close regedit.​
Updated 2-8-2008 to include METHOD TWO for devices with removable storage, like a DVD drive.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
You're welcome RexNoctis, and welcome to Vista Forums. :party:
Thanks to Member:AvatarOfTheShip for providing the tip in Method Two.
I have 2 virtual CD/DVD drives that I use for mounting ISO images. They show up in
windows explorer as
(S: DVD Drive
(T: DVD Drive
I applied the method 2 registry changes to rename to Virtual Drive. The results were
(S: DVD Drive - Virtual Drive
(T: DVD Drive - Virtual Drive
It appended the registry key name to the existing name. Is there any way to completely rename the drives so that it will appear as
(S: Virtual Drive
(T: Virtual Drive
Hi Dennis,
Not that I'm aware of. I could only get to add the name to the end too.
Sorry, :(
I experience the same problem as dennisthemenace with the DVD drive/virtual drive.
But it works fine for my multi card readers and ReadyBoost USB key.
It does not work for the card reader of my networked printer (I.e.: a mounted drive from a networked location)
O.
    Home made
    Intel Core2Quad Q6700 2.67Ghz
    Asus Extreme Striker II
    4GB Kingston HyperX DDR2 800Mhz
    Two NVidia GeForce 8800 GT
    On board
    DELL 2001FP + Samsung SyncMaster 2493HM + Dell 2005FPW
    1600x1200 + 1920x1200 + 1680x1050
    RAID 0 with two Western Digital Raptor 36GB 10000 RPM Sata 300 (WD360ADFD) for the OS and softwares
    RAID 0 with two Western Digital Raptor 150GB 10000 RPM Sata 300 (WD1500ADFD) for virtual machines.
    RAID 1 with two Samsung SpinPoint 500Gb 7200RPM S
    Antec TruePower Quattro 850W (TPQ-850)
    Antec P182
    Logitech Cordless Elite Keyboard (Bluetooth)
    Logitech Mx900 (Bluetooth)
    6Mb/s
    Big fan of VMWare. Using Windows Home Server as a backup solution and MCE (Vista Home) on my HTPC.
Hello OgeGOon,
I'm sorry, but it does not work with virtual drives or printers. :(
Renaming DVD/CD ROM Drives
My question is:
I changed the names according to the directions in the post. Now I have something that looks like this: DVD RW Drive G: Dell DVD Burner or DVD RW Drive I: Samsung. I want to get rid of the beginning part, DVD RW Drive. Is it possible?
    ME
    Intel i7-929 Nehalem 2.66 GHz LGA 1366-quad core
    ASUS Rampage II Extreme
    6 GB OCZ Reaper 3GB (3x2GB)Triple Channel
    Nvidia Gforce 7800 GT
    Supreme FX-X-Fi
    1x 22 inch Samsung SyncMaster 226BW, 1x17in Dell
    MAX-1680x1950-Samsung, 1280x1024-Dell
    1x750 GB
    1x200 GB
    1x160 GB
    1x120 GB
    Themaltake Thoughpower 850 Watt
    Thermaltake Spedo Case
    6 fans on case for now
    Logitech G-15 Gaming Keyboard
    1x Logitech Mx-Revolution, 1x Logitech G-9
    AT&T Uverse
    Cooler Master V8 Heatsink and Fan
Hello Homeuser,
Sorry, but not that I am aware of with removable drives. :(
Ok, Thanks!
    ME
    Supreme FX-X-Fi
    1x750 GB
    1x200 GB
    1x160 GB
    1x120 GB
    AT&T Uverse
You're welcome. :)
You're welcome G1987x1, and welcome to Vista Forums. :)
