System Properties - Add to Computer Context Menu
How to Add "System Properties" to Computer Context Menu in Vista
This will show you how to add System Properties to the Start Menu Computer (My Computer) context (right click) menu in Vista.
Normally you would have to either open the Control Panel (Classic View) and click on the System icon or right click on the Computer button in the Start menu and right click on Properties, then click on the Advanced system setttings link to open the System Properties window. (See screenshot below)
EXAMPLE: System Properties window
NOTE:
This is what will open when you click on the System Properties context menu item below when added and click Continue for UAC prompt.
EXAMPLE: Start Menu Computer context menu Before and After System Properties added
OPTION ONE
Using a REG File Download
1. To Add System Properties
Add_System_Properties.reg
download
B) Go to step 3.​
2. To Remove System Properties
Remove_System_Properties.reg
download
OPTION TWO
Manually in Registry Editor
1. Open the Start Menu.​
Code:
HKEY_CLASSES_ROOT\CLISD\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell
5. To Add System Properties
A) In the left pane, right click on shell and click on New, then Key. (See screenshot above)​
B) Type System Properties and press Enter. (See screenshot below)​
C) In the left pane, right click on System Properties and click on New, then Key.​
D) Type command and press Enter. (See screenshot below)​
E) In the right pane, right click on (Default) and click on Modify.​
F) Type Control sysdm.cpl and click on OK. (See screenshot below)​
NOTE: This file is located at C:\Windows\System32\sysdm.cpl if you wanted to create a shortcut for System Properties.​
G) The registry will now look like this. (See screenshot below)​
H) Go to step 7.​
6. To Remove System Properties
A) In the left pane, right click on System Properties and click on Delete. (See screenshot above)​
7. Close regedit.​
  • Add_System_Properties.reg
  • Remove_System_Properties.reg
