Services
How to Disable or Enable Vista Services
This will show you how to enable or disable a Service in Vista with the help of an advice guide. The guides have different levels of recommendations. Services are a computer program or process that runs in the background and provides support to other programs in Vista.
If you want to cut down the overhead of what is running in the background and speed Vista up some, then only disable the services you do not use. If you disable a service that you need or use, then it could actually lower your computer's performance. The Services apply to all users on the computer.
Configuration Information:
  • Automatic - With a service in this state, it will start at boot time. Some services, when no longer required, will also automatically stop when not needed. If you find you do not need a service, place it into Manual or Disabled.
  • Automatic (Delayed Start) - With a service in this state, it will start just after boot time. Some services, when no longer required, will also automatically stop when not needed. If you find you do not need a service, place it into Manual or Disabled.
  • Manual - Manual mode allows Windows to start a service when needed. However, very few services will start up when required in Manual mode. If you find you need a service, place it into Automatic.
  • Disabled - This setting will stop a service from starting, even if needed. Errors in the Event Viewer will show up complaining of that fact. Some services, while Disabled, will constantly complain. However, this situation is taken care of if placed in Manual. The service descriptions identifies those that should be in Manual vice Disabled.
  • Started - A service that either set to Manual or Automatic that is running by default at or shortly after boot time.
  • Stopped - A service that is not running by default at or shortly after boot time.
You should Export a text list of your sevices and their settings, or take screenshots of them, before you make any changes as a backup. This will be handy if you need to use it to set a Service setting back to what it was later. In the Services window, right click on Action and Export List.
If you disabled the wrong service and lost access to the computer, try booting into Safe Mode to change the service back.
1. Open the Start Menu.
2. In the white line (Start Search) area, type services and press Enter.
3. If prompted, click on Continue in the UAC prompt, or provide the administrator password to approve.
4. Right click on the service you want to disable or enable and click on Properties. (See screenshot below)
5. To Disable a Service
A) Click on the Stop button and wait a sec for it to stop. (See screenshot below)​
B) Next to Startup type, click on the drop down menuand select Disable.​
C) Click on the Apply button.​
NOTE: If the service will not stop and gives a error, then you will need to restart the computer to stop it after you set it to Disabled and clicked on OK.​
D) Go to step 7.​
6. To Enable a Service
A) Next to Startup type, click on the drop down menu and select Automatic or Manual and click Apply.​
NOTE: See the guides above to help decide.
B) Click on the Start button.​
NOTE: If the Start option is grayed out and will not start, then you will need to restart the computer to start it after you set it to Automatic and clicked OK.
7. Click on OK.
8. Close the Services window.
NOTE: You may need to restart the computer for some changes to the services to take affect.
I'll try the links, thanks.
I'm beginning to think seeing a real time view of how well your box runs Shawn would just be nice, :)
Jerry
    home build
    AMD Phenom II X4 955
    MSI K9N2 SLI platinum
    4gb
    2 Nvidia 9800gt's SLI'd with 660 core clocks, 512mb ddr3 ea.
    runs thru home stereo, 7.1 channel
    22" Samsung
    c: 320gb maxtor, d: 1tb wd, e: 500gb maxtor, g: 500gb hitachi, 2 external 500gb wd's in enclosures
    750w Corsair
    Zalman
Jerry, it's usually runs pretty great. However, with all of the tinkering I do, I'm bound to mess it up good at least one time every few months. Thank goodness for a complete pc backup. ;)
Thanks for this. :D I have often wondered just how many of these services can be stopped without major problems. The blackviper link looks like a very intelligent point of departure. :geek:
I was surprised how many services were running that require hardware I don't even have installed -- like TV scheduling for Media Center :mad:!!!
    Intel Core 2 Quad Q6700
    Intel DX975XBX2
    4 X 2GB Corsair PC6400
    2 X ATI Radeon HD 2600XT
    2 X 2 X 500Gb RAID 0
You're welcome Hogtowner. The BackViper did a great job with his guide.
Thank you Krisdestruction for sharing this tip. It has been added to the tutorial.
Thanks brink I've been looking for this list long time ago, was scared to play configure these since I really don't know what are they or is it safe to close them ^^
    Q6600 OCed till 3.3Ghz
    Nvidia XFX nForce 780i SLI
    2X2GB Corsair DDR2 800Mhz OCed @ 820Mhz
    2xNvidia 9500 GT SLI OCed @ 730Mhz each.
    Motherboard Built in
    Acer 22' LCD + 18.5 Wide Samsung LCD
    Internal 2x250 GB SATA II Maxtor, External 500GB SATA WD,
    600Watts
    GIGABYTE
    GIGABYTE Volar CPU Cooler
    Prestigio
    Samsung Pleomax
    2Mbps
Hey Is There A List Of What Services can be Disabled safely ?? :D
Thank you in advance
    Dell Xps M1530
    Intel Mobile Core Duo T7250 @ 2,00Ghz
    Dell Inc 0xR509
    DDR 2 Dual Chanel 2 Gb
    NVIDIA GeForce 8400M GS 128 mb
    ST9160821AS 149 gb
    24/1 mb but actual speed is lower
Hello Antonyua,
In STEP ONE of the tutorial, the links will have a guide for recommended Services settings. At the far right of this guide, there will be a "Safe", "Tweak", and "Bare Bone" column for recommendations for that level. ;)
oh I missed that Thank You! :D
    Dell Xps M1530
    Dell Inc 0xR509
    ST9160821AS 149 gb
LOL, you're welcome Antonyua.
Hello Larry, and welcome to Vista Forums.
No, they are the same for the 32-bit and 64-bit Vista. You only have a few more that are added when SP1 is installed. :geek:
You're welcome Larry.
Re: update "Services" artcile
at...
http://www.vistax64.com/tutorials/59910-services.html
Ref. step one: services guide: 1. for "vista with SP1", the ref'd hotlink ("Windows Vista Service Pack 1 Service Configurations by Black Viper") appears outdated as the resulting web page is for SP2.
Ref. step one: services guide: 1. for "vista without SP1", that ref'd hotlink ("Windows Vista Service Configurations by Black Viper") is tagged as no longer maintained and the hotlink might best now be Windows Vista Information
  • Other Info
    DV4 HP Pavilion Notebook & Acer AOA150 Netbook
Thank you Wguru,
I have updated the guide links. :)
It's 2016--none of the links are valid, and I would also like to know of a .reg file that resets all my services to default. There is no way in the OS to do it--no right click, no button, nothing--a terrible shortcoming.
Also, a services optimizer that covers ALL the services--that would also be terrific.
Again, something that is valid for 2016. Blackviper and the other websites are long gone.
Thanks.
    Compaq Presario SR-5601P
    AMD K6 Dual Core 4400
    2GB
