Internet Explorer - Maximum Download Sessions
How to Change Maximum Download Sessions in Internet Explorer 7
This will show you how to change the number of simultaneous downloads from a web server to what you set them to for only the current or all user acounts. 10 is usually a good maximum. 2 is the default maximum.
  • The current HTTP specification limits the number of simultaneous file downloads to two downloads, plus one on stand by. As connection speeds increase, the number of simultaneous downloads to a single web server may not be enough for your needs.
  • If you visit a web page with lots of images (and supporting files like CSS styles and Javascript), then you can have a slower browsing experience. On average, your browser would have to make more than 40 requests to the server before it can assemble the complete page. Requesting all the files you need with the default 2 at a time is going to be slower than requesting say 10 files at a time.
This will work with any other web browser you are using as well. For example, FireFox.
OPTION ONE
For the Current User Account Only
Using a REG File Download:
Current User 10Max.reg
download
2. Click on Save and save the .reg file to the desktop.​
3. Right click on the downloaded .reg and click on Merge.​
4. Click on Run, Continue, Yes, and OK if prompted.​
5. Log off and log on, or restart the computer to apply the changes.​
6. When done, you can delete the downloaded .reg if you like.​
Manually in Registry Editor:
1. Open the Start Menu.​
4. In regedit, go to: (See screenshot below step 5)​
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings
5. In right pane, right click on a empty area and click on New and DWORD (32-bit) Value.​
6. Type MaxConnectionsPer1_0Server and press Enter.​
7. In right pane, right click MaxConnectionsPer1_0Server and click on Modify. (See screenshot below)​
8. Dot Decimal, then type 10 and click on OK. (See screenshot below)​
NOTE: The default value is 2, but you can change it to your needs.
9. Repeat steps 5 to 8 above, but use MaxConnectionsPerServer instead now.​
10. When done you should see this below boxed in red.​
11. Close regedit.​
12. Log off and log on, or restart the computer to apply the changes.​
OPTION TWO
OPTION TWO:
For All User Accounts
All Users 10Max.reg
download
  • All Users 10Max.reg
  • Current User 10Max.reg
Thanks Shawn, this one was well needed.
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    Drive
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Surface Ergonomic.
    Logitech Performance MX
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Your welcome.
I found plenty of references for the Current user out there, but nothing for All users. I thought people would like to have a choice.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
niGht kiD,
I have not tried it with FireFox, but I believe it should. You can test and see by trying to download more than 2 items from the exact same website at the same time.
Thank you niGht kiD for confirming that it works with FireFox as well.
The tutorial as been updated for this.
Shawn :geek:
Just curious, what does (16) after the value of 10 stand for?
    Dell Inspiron 530
    Intel Core 2 DuoE4500 2.20G
    3.00G DDR2, 667MHz
    Intel G33/G31 Express 320
    Realtec ALC888 (7.1 Channel audio)
    Dell 22" E228WFP
    Samsung HD501LJ ATA 500 G
    PBDS DVD+RW DH-16W1S ATA
    MAXTOR 320 G USB
    5.28 Mb/s Down, 0.64 Mb/s Up, ATT Dry Loop DSL
Hi hdbg62,
The 10 is the hexadecimal number and 16 would be the decimal number for the same number if you were to enter either one in step 8 and dot the correct hexadecimal or decimal option for it.
Thanks for the information; any relation to 1.6 kilometers to the mile (just kidding)?
    Dell Inspiron 530
    3.00G DDR2, 667MHz
    Dell 22" E228WFP
    MAXTOR 320 G USB
LOL, it would not surprise me if it was. ;)
I noticed ya'll said that it work with Firefox. Does this accomplish the same thing as altering the MaxConnectionsPerServer in about:config? In other words, should I apply this to my registry if I've already altered them in Firefox?
    Intel Core Duo E6600 (Conroe)
    Gigabyte P35-DS3R (Rev. 1.0)
    Corsair 2x2048-6400C4DHX
    NVIDIA GeForce FX 5500
    Creative Sound Blaster Audigy SE
    Samsung SyncMaster 720n
    Seagate Barracuda 7200.10 500GB ST3500630A
    Ultra LS 500Watt
    PowerUp 5511 Silver ATX Mid-Tower TC3J-4032 P
    Cooler Master X Dream 4
    Logitech Internet 350
    Logitech RX300
    21.46Mb/s
Hi Carolina,
It really does not matter.
With regards to the max number i think that the Hexa value should be 0a (10) instead of 10 (16)
Wait for Shawn to confirm.
Doh! :o
Thank you Sid for catching this. The tutorial has been updated to use the correct Decimal settings not Hex.
Avant Browser is an overlay on IE, I believe - so applying this to the IE settings makes Avant use it as well.
Avant Browser::Support
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech G15 (gen 2)
    Logitech MX Master (shared)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
what about Avant Browser ?
Hi ReD_FoX,
Yes, it should work for any web browser program. It is a universal setting in Vista that is not specific to just IE7.
This newbie could use a bit of help. Used the download method on "OPTION TWO" and this is what I have now in
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Internet Settings:
MaxConnectionsPer1_0Server REG_DWORD 0x0000000a (10)
MaxConnectionsPer1_0Server REG_DWORD 0x00000010 (16)
MaxConnectionsPerServer REG_DWORD 0x0000000a (10)
MaxConnectionsPerServer REG_DWORD 0x00000010 (16)
Is this correct or should everything be at (10)?
I've made no changes in HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings, in fact I don't even show a setting for
MaxConnectionsPer1_0Server or MaxConnectionsPerServer there
    Dell Inspiron 530
    3.00G DDR2, 667MHz
    Dell 22" E228WFP
    MAXTOR 320 G USB
Hi Hdbg62,
You should only have one set in the HKLM section. See the screenshot below step 12 in Option Two.
You will have to create the entries in the HKCU section, but it is not necessary if you have them in the HKLM section since it affects all user account.
The number in the (10) brackets is the Decimal value for 10 in Modify, and the 0x0000000a is the Hexadecimal value for 10 in Modify.
