Major Problem, URGENT HELP PLEASE, guys
amplid
Vlaming
Power User
Hey guys,
I was on my pc the other day and I was starting up COD2 and just like that, windows went down and I got this blue screen saying windows had been shut down to prevent damage or something. After that the pc rebooted and everything was fine, except for some flickering of the screen sometimes which I knew wasn't good. Yesterday I booted my pc and the same thing happened when I started COD2. Today my pc didn't even boot anymore, right after the IDE screen (black and white) the blue screen popped up showing the same message and the pc shut down. Only safe mode will work. Can this have anything to do with CPU instability or overheating?
Please help guys, but oh well I know this great forum and its users won't let me down;)
Amplid who is scared ****less...!:)
    Asus ROG Striker 2 Extreme
    2 x 2Gb Patriot DDR3
    XFX GeForce 9800 GTX+
    Creative Supreme FX 2
    Neovo F417 17''
    Samsung SP2504C SATA 7200rpm
    Pc Power & Cooling 750
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
Hey guys,
Hi Amplid
Could you possibly let us know what the error code for the BSOD (Blue Screen Of Death) was? For example:
IRQL_NOT_LESS_OR_EQUAL
Stop 0x0000000A
Also, did the BSOD mention a filename of some kind that could possibly belong to a driver?
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
Hey Dzomlija! Thanks for the quick reply. Yes I'd already seen that name somewhere, thought it might be that, cool name:p But ok, I also ran a chkdsk in safe mode and the error code was: I had three different ones: 1: DRIVER_IRQL_NOT_LESS_OR_EQUAL, 2:PC_INDEX_MISMATCH, 3: an attempt was made to write to read-only memory. i also got a file name I think, an nVIDIA driver I guess: nvstor64.sys ... Does that help? Why does he give me different reasons? Could I really have done that much wrong...:s
It also says in the bottom: collecting data for crash dump...
initializing disk for crash dump...
beginning dump of physical memory (DOES NOT SOUND GOOD!!:s:s)
dumping physical memory to disk: 20
And something about disabling caching and shadowing. Should I do this?
Thanks again for quick reply!
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
Amplid
Sorry for taking so long to reply to this post, but my fiancè and I never miss "The Biggest Loser" on TV...
DRIVER_IRQL_NOT_LESS_OR_EQUAL:
Stop 0xD1 messages can occur after installing faulty drivers or system services. If a driver is listed by name, disable, remove, or roll back that driver to confirm that this resolves the error. If so, contact the manufacturer about a possible update. Using updated software is especially important for backup programs, multimedia applications, antivirus scanners, DVD playback, and CD mastering tools.
You mentioned the "nvstor64.sys" file. This belongs to the SATA controller on your motherboard. You should try updating this driver.
PC_INDEX_MISMATCH
I've never sen this one before, and there isn't much about it on Google. What was the STOP code that was displayed with this one? I searched for this on Microsoft's support site and came up with 0 results...
Don't worry about the "dump of physical memory". That's perfectly normal for a BSOD. The data that is "dumped" can likely be used by the programmers at Microsoft to help determine what caused the error. Normal people like ourselves have no use for that info.
As for the caching and shadowing, what you can try is go into your PC BIOS, and carefully go through each of the available sections. Anything that may be labelled "cache" or "shadow" should be disabled, whit the exception of "CPU Cache", which should remain on.
One other setting that you could look for is something about "32-Bit Disk Access". Make sure that those settings are turned on for all hard disks and hard disk controllers.
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
just had a look for PC INDEX MISMATCH and found nothing, however there is a thing called APC INDEX MISMATCH. The information on the web is that this can be caused by a faulty driver.
If you can get hold of the specific drivers for your motherboard and graphics I would reinstall these.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
No problem Dzomlija:) Ok I'll do that in the safe mode. Yes, sorry it's probably APC INDEX MISMATCH, the BSOD came in wrong resolution, so some parts were invisible. I'll update/install/reinstall the SATA driver and if that doesn't work, reinstall all of my drivers, right? What is caching and shadowing?
Thanks guys,
Really helped me as usual!;)
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
Hi Amplid,
Sorry to hear about your latest problem. Since you can get into safe mode, have you tried performing a system restore to a time before you had this problem? Have you been able to run COD2 prior to you having the problem or did the problem occur when you first ran the game? It could be that you need a patch for this game in order for it to work correctly, and that this patch needs to be installed prior to you running the game for the first time. You could also try seeing if other people have had problems similar to yours when running this game. I enclose a link to the Call of Duty website. Check the Forum section.
Dwarf
Infinity Ward
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
Hey Dwarf, thank you for joining in my latest problem;):p:d
Ehmm, oh yes it was working fine! It's not the game, it's something else and I can't do the last known good configuration, because I get the BSOD again when I do that. I'm on the safe mode with internet now, searching for drivers.
Greetings,
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
Hi Amplid,
Just out of interest, did you download and install any optional updates from Windows Update?
Dwarf
    Gigabyte IF233
Well I don't remember really, I just rolled back the driver to the one that was installed in 2007 and so far no BSOD so... But I'll tell you guys how it works out tomorrow, gotta get off pc (mother...:p).
Looking good so far!:D
Night night;):p
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
Night night;):p
Amplid
Not that you'll read this post until later, so I won't say goodnight. Instead, I'll ask if you had a good nights rest.
Hope the problem is sorted...
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
Shadowing is copying areas from rom into ram for faster access. Cacheing is used as a tempory storage area so data can be moved around faster. This is a basic explanation, for more info look at google.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
Yes , I had a fairly good, though shourt, nights rest.:)
I updated the driver for my nForce 430 system management, but it didn't really help...
By now I got two knew failure notes: MEMORY_MANAGEMENT and PAGE_FAULT_IN_NONPAGED_ARIA. the first one I got just once, the other multiple times. I can't boot into my safe mode anymore either, because I get a message saying: Windows Activation: Your activation period has expired. Restart your computer in normal mode to activate windows.
Can this have anything to do with it? I know I have to activate my OS now, but I can't as you see...
Hmm so I updated the ATA controller driver and disabled everything in my BIOS that had anything to with 'cache' (thanks for short info Roy:)), but it hasn't helped so far and I can't boot up, neither in safe(windows activation), nor in normal mode(BSOD)... Could this have anything to do with a Trojan or so?
Greetings,
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
Is it a legal copy installed on one computer? Was it properly activated before you had the issues? Did you do a system restore?
    16GB DDR667
    SAS RAID
Greetings,
Amplid
Hi Amplid
Ouch. It's getting nastier by the second!
There is one other setting in the BIOS that you can check. If anything to do with APIC was turned on when Windows was installed, it could wreak havoc with the installation if it is suddenly turned off. Go have a look see if thats the case.
APIC, fyi, stands for "Advanced Programmable Interrupt Controller".
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
But it wasn't me who installed vista... Or do you mean the driver? How do I check this? Yes it is a legal copy, installed on just one computer. I don't know, I had it installed for me, but I guess most people don't activate it when installing, for if there's a problem. So I don't know reallly, anyway to check it? I just managed to get into my safe mode again, after getting into the normal mode for like 5 minutes and it activated, it said Windows was activated...
No, that's in the BIOS right, system restore? No haven't tried that before...
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
Vista and newer MS applications require activation to use. This includes XP. So it does state its activated once you get into regular mode? What is in the event viewer?
    16GB DDR667
    SAS RAID
Guru, it did ones, when I got it into normal last time: I entered my password and then black screen with only that in the middle, I pressed close and windows opened, so I guess it is. I tried a system restore, but it stopped and I got a BSOD again, should I try to restore it further, or wouldn't that help if it BSOD'd during restore?
Djee man, this really is serious, as a last resort I could reinstall the OS, right?
Greetings,
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
All I found in that Event viewer was: the Windows Process Activation Service entered the running state.
I also found this: the following boot-start or system-start driver(s) failed to load: i8042prt.
Does that help? I can give you the error codes that occur on the BSOD too if it helps...:s
Huh, and look what they saud, explaining that I couldn't open windows update: The Windows Update Service terminated with the following error: Windows Update is not a valid Win32 application.
What is that with 32? I have 64-bit... Or nothing to do with that?
hmm...
Sorry for the many editing, but I think I found one program that's incompatible, that's what event viewer says: In windows, syswow64 a driver called GEARAspiWDM. How can I delete that? Not to the bin right...
there's something about a security package called Kerberos... I didn't install that...
Also the NMSaccesU failed to start, as well as avast antivirus
Also says: DCOM got error 1084 attempting to start the service ShellHWDetection with arguments in order to run the server.
And a lot more of that and the GEARAspiWDM and i0842 errors...
DJEEZES...
Greetings,
Amplid
    Neovo F417 17''
    Coolermaster CM 690
    Logitech G11
    ~1000 Kb/sec
Greetings,
Amplid
Amplid,
You're pretty new with computers and such, right? Let me give you a bit of advise - reformatting and reinstalling should be used as an absolute last resort, when you have exhausted all other means of fixing the problem, and you are 100% sure beyond any shadow of doubt that re-installing is the only way out.
How else are you gonna learn how to fix computers?
But to recap:
You've tried drivers, BIOS settings, and System Restore.
So far, nadda. If you can still get into safe mode, have you tried to use MSCONFIG to disable all non-critical startup programs and services? It can take awhile, but disabling everything and then enabling each one at a time with a reboot untill the problem returns is another method you can try. Once you find the "problem child", keep it disabled, and enable the rest, and hopefully the problem goes away.
EXACTLY what motherboard are you using, and with which BIOS version? Perhaps as a last-ditch effort before reloading Windows you can try a BIOS update? To make sure a BSOD doesn't kill the update process, you'd better do that from a bootable CD or something outside of Windows...
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
