Need help w/ the GUI defragmenter....why doesn't it work??
stcshindo
Last week I bought a new Acer Aspire 6350 w/ Vista - My 1st Vista machine.
After uninstalling all the Acer bloatware, I open the GUI defragger, it analyzes C: for 2 secs (doesn't even mention analyzing the other 2 partitions) then it says "your file system performance can be improved". I defrag it the C:, it takes 45 mins or so and done.
I go to my wife's Dell Vista laptop and go to the GUI defragger. It analyzes all 3 of her partitions. Weird, mine only analyzed C: for 2 secs. I then go back to my new Acer and run the GUI degragmenter again. After a 2 sec C: analysis it says "your file system......." again.
Then when I go the command line defrag, run "defrag c: -a" it says I don't need to defrag.
Bottom line is the GUI defragmenter doesn't work on this new laptop. It doesn't scan all partitions, when started it runs for a bit, then it just stops and it goes back to saying " your file system performance can be improved".
Pls help.
How can I fix this?
    Acer Aspire 6530
    AMD Athlon X2 QL-62 Dual Core 2 GHz Processor
    3GB DDR2 Memory
    ATI Radeon (Mobility) HD 3200 onboard graphics chip
    1366x768
    250GB Serial ATA Hard Drive
I did a search and came up w/ http://www.vistax64.com/general-discussion/193109-defrag-question.html
The OP was having the same problem as me, but there really isn't a solution listed.
I did download Auslogics Disc Defrag. Every single time I run it, it shows 1/2 my drive being fragmented, and it takes less then 45 secs to defrag the C: partition.
It looks pretty, but is it really working? Less then 45 secs seems awfully fast, especially when I go analyze again it still shows 1/2 the drive is fragmented.
Any suggestions?
    Acer Aspire 6530
    3GB DDR2 Memory
    1366x768
Have you looked at the options for disk defragmenter?
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
    Acer Aspire 6530
    3GB DDR2 Memory
    1366x768
Anyone else? Pls help.
    Acer Aspire 6530
    3GB DDR2 Memory
    1366x768
Can you select the volumes. Look at the screenshot below:
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
my first statement is a polite WINDOWS PROGRAMMED DEFRAGGERS CAN GO BURN LIKE MARILYN MANSON AT A BAPTIST REVIVAL! Now that that is out of our system, I suggest Auslogics free defrag or if you've got the cash pony-up for their Boost speed program. I promise you will never want for effective maintenance again!
    Home built
    phenom IIx4 810
    m4a79t deluxe
    8Gb DDR3 OCZ Platinum AMD Edition
    evga 295 co-op and 9800 gtx for PhysX
    Mk241H
    1920x1200
    Seagate Barracuda 7200 750Gb
    ABS Tagan BZ 800W
    Xclio A380PLUS-BK Fully Black
    Asus Royal Knight
    Razor Lycosa Mirror edition
    Logitech 5 button tilt wheel laser (don't remember model#)
    Wireless Road Runner
If you must pay Tune Up Utilities is better in every respect than Boostspeed. JK Defrag is an open source choice and has been recently updated to My Defrag.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Hadn't heard of them before, I've just found Boost speed to be the most user friendly of the ones that had a free trial. Plus is reasonable $$ and can be put on computers adifinitum.
    Home built
    phenom IIx4 810
    m4a79t deluxe
    Mk241H
    1920x1200
    ABS Tagan BZ 800W
    Asus Royal Knight
I can only see what volumes (of the 3 I have) after I click the "Defragment Now" button.
Your pic shows the GUI analyzing 2 of 2....Mine will not even get to that point. It says scanning 1 of 3 (c: ), then 2-3 secs later it says "your file system can be improved". It doesnt scan the 2 volumes.
I appreciate the help.
    Acer Aspire 6530
    3GB DDR2 Memory
    1366x768
Try running Chkdsk - open up Windows Explorer - then right click on your hard drive select properties, tools, and then check now. Then tick both boxes, reboot and wait for the results.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
That was the 1st thing i did when I 1st noticed the problem.
    Acer Aspire 6530
    3GB DDR2 Memory
    1366x768
Have you tried an alternate defragger?
    Home built
    phenom IIx4 810
    m4a79t deluxe
    Mk241H
    1920x1200
    ABS Tagan BZ 800W
    Asus Royal Knight
Yes, I have tried Auslogics Disk Defrag. Thats not the point though, Im curious why the GUI doesnt seem to work.
I ran a couple Google searches and it seems like a few people have this problem, but there hasnt been any solutions.
    Acer Aspire 6530
    3GB DDR2 Memory
    1366x768
just a thought, but are you running defrag under a limited user account? i have never used the gui vista defrag--either command line or more recently, my defrag, formerly jkdefrag.
    Garage PC
    Intel Pentium E3300 @ 2.5GHz
    BioStar G41-M7
    A-Data PC2-6400 (2 X 2GB)
    Diamond Radeon HD 4650
    Realtek
    HP Mx705 (CRT)
    1152x864
    320 GB Hitachi - System Drive /
    100 GB Maxtor - Diagnostic Application /
    LOGISYS PS480E12 480W
    Generic Barebones Case
    Stock Intel HSF
    Generic PS/2
    10 d / 1 u
You can try these 2 shortcuts in this Utilities.zip
Just unzip the file then click on a shortcut and allow it to run (the window will close automatically once its done) Once both shortcuts have run, reboot your pc and then go and try the windows gui defrag.
Nope, Ive ran it using the my acct (admin), under Admin, and even right click "run as Administrtator".
I'll try this tonight. Can you pls explain what the shortcuts will do. I'm new to Vista, and never had defrag issues w/ past Windows.
Thanks!
    Acer Aspire 6530
    3GB DDR2 Memory
    1366x768
hi stcshindo
Sorry theres actually three shortcuts in my zip file. The first is an extended version of disk cleanup which allows you to clean away more trash files and the other two are defrag shortcuts. One of them defrags the boot files and the other defrags all files.
Using the gui defrag it will skip file fragments larger than 64mb but by using the defrag shortcut it will defrag all files regardless of size.
hi stcshindo
Thank you, I'll try this when I get home tonight.
Question....when I click on the your "defrag all" shortcut, is it similar to doing a "defrag c: -w" through the command line?
If so, I have already done that and the GUI still doesnt work.
    Acer Aspire 6530
    3GB DDR2 Memory
    1366x768
