Vista - Intel E8400 Temp problem
Old 04-10-2009   #11 (permalink)
Windows 7 x64
Re: Intel E8400 Temp problem
I think there might be something wrong with the sensors. -27c min temp?
Is it a pre-built computer or did you build it yourself?
I had a lot of incorrect readings on my old Dell PC. I had motherboard temps of -100c.
Old 04-10-2009   #12 (permalink)
Windows 7 Ultimate x64
hMM OK brothers Thx for a good piece of advance. I want to know 1 thing more. Does overheated pc (liek mine sadly) is slower then normal. I notice my GTA4 is laging even on low setting. B4 it work like charm on High settings.
Old 04-10-2009   #13 (permalink)
I build it myself
Old 04-10-2009   #14 (permalink)
Windows 7 x64
Overheated components will begin to throttle themselves, so yea it can result in slower performance.
Old 04-10-2009   #15 (permalink)
Vista Ultimate x64
In cpu-z it shows your running at 1995mhz. With the temps your posting id imagine your pc always runs at that speed and never goes up to the 3Ghz it should.
Old 04-10-2009   #16 (permalink)
Its running at 1995mhz coz intel speedstep is not disabled.
Old 04-10-2009   #17 (permalink)
Vista Ultimate x64
Yeah but its supposed to go up to 3Ghz when you do something like play a game. But in your case id think it wouldnt or at least wouldnt stay there for long as your so close to max temp already that it would throttle your performance so as to avoid damaging the cpu, getting blue screens of death, crashes etc.
Old 04-10-2009   #18 (permalink)
@stew: There were too much dust stroms in my city.
See here Saudi Arabia’s Giant Sandstorm | Shareordie
After this strom i didnt clean my pc. So cleaning pc will solve sensor problems?
Old 04-10-2009   #19 (permalink)
Vista Ultimate x64
WOW. If i was you id move .
But anyway you should clean out your pc just to make sure. Make sure to remove all dust from fans, heatsinks, the motherboard etc.
I dont think all your sensors have gone bad, but clean the pc and if you know how to then you should probably re-apply thermal paste to the cpu and install the heatsink and fan.
Make sure to route all cables as neatly away as possible as well and if possible install more fans.
Old 04-10-2009   #20 (permalink)
Tonight I'll clean the pc and tomorrow morning i'll get a new cpu fan and case fans. Thx alot for ur help bro.
OCing e8400 with asus mobo Overclocking & Cooling
Max overclock with E8400 Overclocking & Cooling
Windows Vista strange settings on temp folder AppData\Local\Temp\1 Vista security
Successful OC e8400 @ 4.00Ghz Overclocking & Cooling
Intel E8400 General Discussion
